[Request] Asus A320M-k updated BIOS Dump
  • BrocKastillo
    replied
    Hello everyone! I have similar problems, I have an athlon 220G and I have 3 boards, all a320mk, 1 is a rev. 1.02 and the other 2 are rev. 1.04.
    The plate rev. 1.02 has a macronix MX25U12873F eeprom, and it worked with the rom, 4011, while the rev. 1.04 have winbond 25q128fwsq eeprom, it doesn't work, I use CH341 with 1.8v, and AsProgramer, the rev. 1.04 turns on the led, and turns on the fan but gives no signal.
    Does the eeprom have anything to do with it?​
    Sorry, im using translate, im speak spanish...
  • SoporteNetFe
    replied
    Originally posted by lucas357
    alguien tiene la versión PRIME A320M-K BIOS 5220 directo de la placa?
    Does anyone have the PRIME A320M-K BIOS 5220 version directly from the motherboard?
    in English please..
    Try this...
  • peste
    replied
    in English please..
    post the S/N, post the original content of the bios chip, the motherboard model, etc.
  • lucas357
    replied
    in English please..
  • neeworam
    replied
    Re: [Request] Asus A320M-k updated BIOS Dump
    Hello there! I was wondering if you could help me figure out how to transfer my serial number and MAC address to a BIN file. Any assistance would be greatly appreciated. Thank you!
  • hardware1
    replied
    Originally posted by wengot
    I downloaded a bios file from asus and its 16mb and I need only 8mb..
    help please
    You should write your device model number, upload your BIOS Backup, take an image for the chip to see what is written on it and add the link of the official BIOS.
  • wengot
    replied
    help please
  • regiman
    replied
    Hi Guys. Here I copy the Original Bios file of a working Prime A320M-K.
  • BELK
    replied
    Originally posted by abel2b
    Well here´s an update, I managed to borrow an AMD Ryzen 3 2200G and with the updated 6402 that I downloaded, extracted and flashed chip, but that the Ryzen 5 4600G did not boot, I installed the the R3 and booted fine, checked the bios it said Ver. 6402, power down, I then swapped the R3 for the R5 and BOOOM! it booted...... WTF!
    can you post your ver.6402 bios dump?
  • abel2b
    replied
    replied
    Originally posted by xstage
    Has this problem been solved, I'm also facing the same thing, I want to upgrade the cpu to r5 4650g, the bios position is 5606 and can't update to version 5862 because I'm using a cpu a6 9500 which is not supported in bios 5862
    Can you post your bios backup
  • xstage
    replied
  • hoaca388
    replied
    Is this actual 5862 BIOS dump or extracted from download ...?
    That file extracted from download. It's clean file.
  • abel2b
    replied
  • hoaca388
    replied
    Try again with 5862 version.
  • abel2b
    replied
    Re: need bios for Asus prime a320m-k
    Originally posted by Reda123456
    Hello i need the dump bios for this Motherboard becouse i have r5 4500 and i can't update the mb to make the cpu work in this mb
    i need ver 5862 or higher than 5862
    E307069 GE-1
    Same here, still haven´t been able to get a dump from an updated "working" board...
  • abel2b
    replied
    Originally posted by hoaca388
    Ch431A is a programmer with poor reliability. Flash the bios file for your chip, then read the chip again and compare with the original file to see if they are the same.
    I have no problem detecting chip or errors during write.. I did a comparison by programming chip, then read content with ASPprogrammer, NeoProgrammer and CH431 software, saved file and compared to original file with HexFlex and HXD and content is the same....
  • Reda123456
    replied
    E307069 GE-1
  • hoaca388
    replied
  • Bad_repair
    replied
    I am also struggling with this board, using a CH341a the newer type with the built in voltage selector switch.
    My board has a Winbond 25Q128FWSQ which is 1.8v, but the chip does not auto detect, I can manually select the closest chip which is the W25Q128FW [1.8] however if I try to erase the chip I get a "Probable erasure failure, check protection bits in status registers"
    I am using the NeoProgrammer 2.2.0.8 with a clip over type device, I don't have to tools or skills to desolder due to very severe shaking, so can't avoid this option sadly.
    I also get "verification error on address: "random hex address" " when I try to do any kind of "off-protect->erase->blank check->write->verify sequence.
    Any help would be appreciated, maybe we can solve the problem for both of us. TIA for any help
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • Sebastian Codrean
    BIOS file for ASUS F542UN laptop
    by Sebastian Codrean
    Hello to all of you! I need help with a BIOS file.
    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
    02-20-2025, 10:25 AM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • kodox
    Asus ExpertBook B1400CB Bios Dump Needed
    by kodox
    need original bios dump, original bios has flashed by other technician before me.
    attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
    unit info:
    Model: Asus ExpertBook B1400CBA-0711A1235U
    S/N: R6NXNZ006657238
    CN: 7F6F
    Mainboard Code: B1500CBA R2.1...
    08-16-2025, 12:20 PM
