ideacentre AIO 3-27IMB05 - Type F0EY la-j771p rev:1.0 bios
  • SCREAM76
    • Jan 2014
    • 53
    • istanbul
    ideacentre AIO 3-27IMB05 - Type F0EY la-j771p rev:1.0 bios please.
    original bios >>>
  • hoaca388
    Badcaps
    • Jan 2022
    • 12322
    Re: ideacentre AIO 3-27IMB05 - Type F0EY la-j771p rev:1.0 bios
    Your serial number ?
    Try :
    • SCREAM76
      • Jan 2014
      • 53
      • istanbul
      Try :
      thank you very much
      • SCREAM76
        • Jan 2014
        • 53
        • istanbul
        Try :
        now i had a chance to try and there is no image. It stays stuck at 0.18A. Device serial no: MP1TLET7
        It also draws 0.92A current with its own bios. It gives 3 short 1 long beeps and there is no picture.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12322
          Try again. The file above I did wrong.
          • SCREAM76
            • Jan 2014
            • 53
            • istanbul
            I tried and the computer gives the same error. It has been stated in the forums that there is a ram error. ram voltage is normal, i cleared the slot, and tried another ram, the situation is still the same. What do you think is the problem?
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • Simon16
              DMI region for Bios Lenovo ideacentre 510-15ABR TYPE 90G7
              by Simon16
              I have written the imageM14.rom file (extracted from lenovo M14JY40USA website update file) to my BIOS chip and the PC now boots but shows a serial number not found message.
              I can't find the serial number in the original BIOS. I don't know how to find the DMI region.
              Can anybody help me?​​
              S/N: R3051Y6R
              BIOS CHIP: W25Q128FW
              PCB: PIPELINE 00XK108...
              02-13-2024, 11:01 AM
              by Vesko356
              08-11-2023, 03:27 AM
            • mximiliandz
              help bios lenovo ideapad s145-14iil type 81w6
              by mximiliandz
              Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
              06-20-2025, 06:50 AM
