Hp elitedesk 800 g1 locked bios
  • Christakos19
    • Dec 2021
    • 28
    • Greece
    i have a bios locked from a pc HP 800 g1 sff!
    Tried with HPunlocker but didnt work.
    If anyone can help i would appreciate it.
    Thanks in advance.
  • Christakos19
    • Dec 2021
    • 28
    • Greece
    Re: Hp elitedesk 800 g1 locked bios
    Anyone can look it up pls?
    • satishkumar
      • Sep 2015
      • 164
      • India
      Thanks in advance.
      Check and Reply
      • Christakos19
        • Dec 2021
        • 28
        • Greece
        Originally posted by satishkumar
        Check and Reply
        This is a different bios than mine as i can undestand comparing them so it will need DMI info and i want to avoid that.
        So i would like if someone can unlock mine as it is!
        Thanks in advance!
        • satishkumar
          • Sep 2015
          • 164
          • India
          Thanks in advance!
          password removed or not ???
            • 21852
            Thanks in advance!
            Did you try RCUnlocker
            • Christakos19
              • Dec 2021
              • 28
              • Greece
              I didnt programmed it cuz i saw its another version than mine m8. If no one can unlock it i will do it and post!
              • Christakos19
                • Dec 2021
                • 28
                • Greece
                I tried the HPUnlocker not the RC one!
                • Christakos19
                  • Dec 2021
                  • 28
                  • Greece
                  Is that normal pop up?
                  • Christakos19
                    • Dec 2021
                    • 28
                    • Greece
                    Update.
                    The bios has a Stringent password enabled.
                    That restricts the jumper password removal thats why i asked your help!
                    • Christakos19
                      • Dec 2021
                      • 28
                      • Greece
                      Check and Reply
                      I programmed the bios you sended and entered DMI info but it doesnt get mac address and i cant input it.
                      Any help on that?
                      P.S. Other than that it seems to working fine.
                        • 21852
                        Any help on that?
                        Try ASRock MAC address tools
                        https://www.badcaps.net/forum/showpo...10&postcount=4
                        • Christakos19
                          • Dec 2021
                          • 28
                          • Greece
                          Tried but got the following fail message.(see foto1)
                          Also i have installed the ethernet driver but its still like this.(see foto2)
                          • wolf3d.exe
                            • Jan 2023
                            • 33
                            EliteDesk 800 G1
                            I have multiple EliteDesk 800 G1, i5 4th gen, board no pdqlb0mcy7gngf.
                            BIOS chip in question is MX25L12873F.
                            I need to re-program the BIOS in order to remove the password, apparently PSWD jumper doesn't help. I am NOT an expert on BIOS re-programming so please bear with me.
                            I used ch341a with "CH341a programmer" software to read and save the BIOS dump BEFORE sending it to RCUnlocker. I've got my _unlocked file and tried to re-program with "ch341a programmer". That end up being no success, software was throwing error like "memory and chip contents are in disagreement" kind of error message.
                            I later tried AsProgrammer, that told me I might have "possible write protection", I re-programmed the chip with auto button with _unlocked bin, soldered back to mobo, no post, fans full speed.
                            Now even if I want to put the original BIOS back it says "File size larger than IC size"
                            Is there anything special with this chip? What is my mistake here? I attached the original BIOS dump.
                            Any help will be greatly appreciated.
                            ** UPDATE ** I ended up flashing BIOS but having hard time with NIC card. It doesn't work (no PXE, yellow sign in windows) I tried ASRock NIC tool, same as the poster before me it said platform not supported. Then I tried eeupdate with correct NIC, it changed the MAC address but still same issues. I attached the working BIOS with NIC issues (which was also downloaded from forum)
                            • wolf3d.exe
                              • Jan 2023
                              • 33
                              Did you solve your problem with the NIC?
                              • alfredposadas09
                                • Aug 2020
                                • 342
                                • Philippines
                                Thanks in advance.
                                your dump file has no dmi can u send me the serial number of your unit?
                                • alfredposadas09
                                  • Aug 2020
                                  • 342
                                  • Philippines
                                  Thanks in advance.
                                  try this i hope it helps to remove password
                                  • alfredposadas09
                                    • Aug 2020
                                    • 342
                                    • Philippines
                                    Re: EliteDesk 800 G1
                                    try this sir and update me if the password sucessfully removed
                                    • tahirkhan1983
                                      • Feb 2012
                                      • 16
                                      Need Bios for my 800 g1 mother board with dump attached. Thanks
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • BrentH561
                                        Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
                                        by BrentH561
                                        Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
                                        Here is the hardware identification specs:
                                        HP EliteDesk 800 G6 SFF
                                        Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                        Serial No: MXL1223499
                                        Product No: 26S74UT#ABA
                                        BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
                                        08-23-2024, 08:36 AM
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • limann
                                        Bios HP EliteDesk 800 G3 Mini 65W
                                        by limann
                                        I need Bios for HP EliteDesk 800 G3 Mini 65W, please support
                                        *Serial No : 8CG7427T48
                                        *MB Info : Scorpius MB Rev A
                                        16515-1
                                        348.06N35.0011
                                        *Proplem : No power on - 3 flashing red & 5 white, speaker : beep bep beep
                                        Thank you...
                                        10-02-2025, 07:53 PM
                                      • tay147895412
                                        HP EliteDesk 705 G1 mini request for bios modding
                                        by tay147895412
                                        Hi, I have an HP EliteDesk 705 G1 mini.
                                        Model: HP EliteDesk 705 G1 Desktop Mini
                                        Processor: AMD PRO A8-7600B
                                        Motherboard PCB Marking: "APCB M3 94V-0" / "NPGC N-150TL"
                                        BIOS Chip: Winbond 25PE20VG (2 Mbit SPI, 3.3V, 8-pin SOIC) and MX25L6473E 64Mbit (8MB), SPI NOR, 3.3V, 8-pin SOIC
                                        Could someone help me with my bios , request:
                                        unlock MPM/DMI with a BIOS patch/mod , dc tay42069 if someone could help me pls
                                        Im gonna leave down below my working bios, if someone could mod it so it has the mpm...
                                        07-02-2025, 02:23 PM
