Dell Optiplex 3060 bios
  • OntarioTL
    • Feb 2022
    • 51
    I work for a Laptop/Desktop refurbishing company. We just came across a bunch of Optiplex 3060's that when Windows is installed, it will pop up with the original owner company if connected to the internet. This renders us from being able to resell them again.
    I thought about it might be the Dell bios, but that doesn't make sense for it to be able to make windows do this. So I'm guessing it is the embedded windows key to call Microsoft home and the original ownership with this key is then somehow overides the activation to show their company name and property of etc.
    I tried to even just put in a generic windows key to see if I can override the embedded, but it looks like it still calls this key.
    What I am wondering if I pull the bios to file, is it possible to wipe the embedded key from the bin file. And if so, is it easy enough to do? I think we have at least 50 units to do so it would be a pain to ask someone here to help with all the units we have.
    • 31032
    Re: Dell Optiplex 3060
    it could be malware in the bios called "computrace"
    it can phone home and patch windows on the drive before it even boots!
    • OntarioTL
      • Feb 2022
      • 51
      Yeah I checked that. It was enabled but not activated. I disabled nonetheless however still greeted with this when you try to enter into Windows 10 from a fresh install. It only happens with connected to the internet, so it must be associated with the OEM key. Btw this is from a x1 carbon with the same issue.
      Normally we would attempt to contact the former owners, but most just don't know what the hell we are talking about or they just tell us too bad.
      • param
        • Dec 2020
        • 9
        • india
        optiplex 3060 bios please send
        • peste
          • Dec 2016
          • 12835
          • ROMANIA
          post the original bios ..
          • param
            • Dec 2020
            • 9
            • india
            please send optiplex 3060 post
            • dhan
              • Jun 2018
              • 134
              • hp
              Please help to remove password
              • hoaca388
                Badcaps
                • Jan 2022
                • 11768
                If you can find and change the window key in bios file, the problem can be solved.
                • jayeshkoodali
                  • May 2017
                  • 3
                  • india
                  can anyone help optiplex 3060 bios
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11768
                    Post your corrupt bios file.
                    • dhan
                      • Jun 2018
                      • 134
                      • hp
                      Re: Dell Optiplex 3060 bios
                      Please help remove admin password
                      • Stunt
                        • Oct 2019
                        • 182
                        • South Africa
                        Device: Dell Micro
                        Brand: Dell
                        Model: Optiplex 3060 Micro
                        Board Number: IPCFL-CG
                        Service Tag: 8P0NYW2
                        Request: Bios Repair
                        Issue: Remove bios lock and Company logo
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11768
                          Originally posted by Stunt
                          Device: Dell Micro
                          Brand: Dell
                          Try and feedback
                          • Stunt
                            • Oct 2019
                            • 182
                            • South Africa
                            Originally posted by hoaca388
                            Try and feedback
                            Thanks man you a star i really appreciate your time
                            • benweston
                              • 8
                              Device: Dell Micro
                              Brand: Dell
                              HI, what are you using to read/write the bios?
                              I am trying to flash a suspected corrupt bios on a 3060 micro with a CH341A and can't even read the chip, I used this programmer to reflash some x99 motherboards with no issue recently.
                              I am using an SOP16 to DIP8 clip and I have tried with JP1 on the motherboard in the standard position and the service position with the same result.
                              • alfredosn
                                • Jun 2016
                                • 19
                                • México
                                Hello friends, I have a Dell Optiplex 3060 with symptoms of bios corruption, can someone help me reprogram it please, thank you.
                                Device: Dell Micro
                                Brand: Dell
                                Model: Optiplex 3060 SFF
                                Board Number: WHW95
                                Issue: Corrupted bios​
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11768
                                  Device: Dell Micro
                                  Brand: Dell
                                  Board Number: WHW95
                                  # 13
                                  • ali0robot
                                    • Mar 2023
                                    • 72
                                    • N/A
                                    hi friend,
                                    could someone help me to put this bios bin in manufacturing mode.
                                    thanks in advance
                                    dell optiplex 3060
                                    servive tag: 5hry8v2
                                      SMDFlea commented
                                      Editing a comment
                                      Just try the bios at post #13
                                  • ali0robot
                                    • Mar 2023
                                    • 72
                                    • N/A
                                    bios doesn't have any problem, I just need in mfg mode to program in different machine
                                      • 20961
                                      You make it sound so easy when you put it like that, but you don`t know how much work is involved in making your "bios doesn't have any problem" bios into one that you can use in another machine. The bios at post 13 has clean ME firmware, no service tag. If you want to use your own bios then clean the ME firmware, extract the bios region from the dell bios update,after extracting it, and copy it over your bios region using a hex editor or UEFITool 0.25/0.28 .
                                        DELL OptiPlex 3060 OptiPlex 3000 i5-8500T Specification for Upgrade or Repair
                                        This specification for the DELL OptiPlex 3060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3060 boardview and OptiPlex 3060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                        09-12-2024, 03:44 PM
                                        DELL OptiPlex 3060 OptiPlex 3000 i5-8500 Specification for Upgrade or Repair
                                        DELL OptiPlex 3060 OptiPlex 3000 i3-8100 Specification for Upgrade or Repair
