hello there i have intel motherboard with damage bios file i tried another file and it startup normally but i need to reapair the original bios because ther is a program wich installed on the motherboard wich is related to ther serial number
need help in reapairing intel DG43NB motherboard BIOS file
need help repair Bios for intel DG43NB
i have sediv pc to repair hdd it became not startup because bios error i found a good bios and it made the pc work fine but the installed software didnt work so i need to repair the original bios and i attached the good bios -
Re: need help repair Bios for intel DG43NB
try thisAttached FilesComment
i want to know the bios version of this intel DG43NB DUMP
please any one can help me to know the bios version of this intel DG43NB DUMPAttached FilesComment
Re: need help in reapairing intel DG43NB motherboard BIOS file
try this one. which software are you talking about ?Attached FilesComment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by valdesonI request the BIOS file for the motherboard som-6867 rev-a1 19a6686701-01 from the brand Advatech.
- Loading...
