Dell Optiplex 7090 10gen password 8fc8
  • Meda1987
    • Feb 2021
    • Serbia
    #61
    Re: Dell Optiplex 7090 10gen password 8fc8
    is this works with any Optiplex 7090 Tower
    • Arrow16
      • Apr 2022
      • 229
      • Philippines
      #62
      Upload your dump someone will unlock for you
      • BoberMod
        • Sep 2023
        • 3
        • Ukraine
        #63
        Hi!
        I bought a Dell Optiplex 7090 SFF offhand in my country. I plan to use it as a server for HA, Plex, etc. But I have encountered that there is an admin password in BIOS.
        The problem is that PC itself has been resold several times, and its path is Sweden - Poland - Ukraine. So I don't have owner's contacts and can't ask password.
        I've been in contact with Dell support in Ukraine. PC is under warranty, but they can't help with password because I need to transfer warranty to my country and provide purchase documents, which I just can't do.
        After some research, I saw paid solutions, but then I found your forum with lots of information.
        I've read "BIOS guides, methods, resources and tools" topic, but I don't have a programmer to dump the bios from the current system. I read that it's possible to patch bios update file to remove password (or related functionality) from it.
        I extracted bios files using "Dell_PFS_Extract", but:
        1. It contains 2 BIOS: EVT_BUFFALO and EVT_CHPB_BUFFALO and I don't know which one should be patched.
        2. Each BIOS contains a lot of .bin files. I understand that BIOS itself is "1 System BIOS with BiosGuard v1.19.0.bin" file, but I'm not sure how to merge it together to get a single .bin file.
        Service tag: 72GTSH3-8FC8
        Attachment contains only 1 BIOS because of size limits - EVT_BUFFALO.
        Please, can you help me?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12118
          #64
          Originally posted by BoberMod
          Hi!
          You need dump bios file from device or no ways .
          The cheapest is CH341A.
          https://www.badcaps.net/forum/showpo...40&postcount=2
          https://www.youtube.com/watch?v=4qX2...annel=Miyconst
          • BoberMod
            • Sep 2023
            • 3
            • Ukraine
            #65
            I got T48. Here is BIOS dump.
            I saved it in the "default" buffer and flash. I'm not sure which one is correct, but I would assume flash because it's exactly 32MB.
            Please, can you reset password?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12118
              #66
              • BoberMod
                • Sep 2023
                • 3
                • Ukraine
                #67
                Thank you! I fleshed patched firmware, but got "status reg error" on verification step (see attached screenshot). I skipped status reg verification and started PC just to check.
                I entered manufacturing mode and set up the same service tag. After reboot, I disabled manufacturing mode using ALT + F.
                After that, everything ran OK, with no errors in BIOS log, and no problems with BIOS settings. (Haven't tested the VMT yet)
                But I also checked diffs between original and patched flashes - the end of the patched file is FF FF...
                Could this affect anything in the future? Should I replace this with data from original firmware and flash it again?
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12118
                  #68
                  What you mean is this ? That doesn't affect anything.
                  • zaphodq
                    • Oct 2023
                    • Hi
                    #69
                    Damaged 7090.
                    Could someone unlock admin password please?
                      • 21467
                      Originally posted by zaphodq
                      Damaged 7090.
                      You must post the service tag as per the rules - https://www.badcaps.net/forum/showthread.php?t=103569
                      • ELBONGO
                        • Oct 2023
                        • MEXICO
                        #71
                        Hi there, I need some help my BIOS is admin locked
                        Service Tag: DKK5RN3-8FC8
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12118
                          #72
                          Post backup bios file.
                          • PacoGT
                            • Sep 2022
                            • 102
                            • Guatemala
                            #73
                            hello i need,
                            you unlock admins password on bios and
                            clear me all in the biios thanks
                            is a dell 7090 micro desktop
                              • 21467
                              Originally posted by PacoGT
                              hello i need,
                              Post the service tag,and read the rules and guides.
                              https://www.badcaps.net/forum/showthread.php?t=103526
                              • AMN servis
                                • Nov 2015
                                • 10
                                • BiH
                                #75
                                Hello
                                admin password, please
                                service tag: 2ZXCJH3
                                • Phuoc Tan
                                  • Dec 2021
                                  • 17
                                  • Vietnam
                                  #76
                                  Originally posted by AMN servis
                                  Hello
                                  Try and feedback
                                  • AMN servis
                                    • Nov 2015
                                    • 10
                                    • BiH
                                    #77
                                    The admin password has been removed , but m2 ssd slots dont works.They work perfectly with the original dump.
                                    thank you.
                                    • Sudoer
                                      • Sep 2019
                                      • 36
                                      • Israel
                                      #78
                                      Hello.
                                      The problem is STATUS REG ERROR at: 0001 Buffer Value :0x02 --- IC Value : 0x03 When I burn flash from badcaps or even dump from GD25B256EFIR . And after flash process, motherboard shows error 3-5 (memory problem). But everything was OK except admin password. What I did wrong ?
                                      • salawayon
                                        • Nov 2012
                                        • 577
                                        • philippines
                                        #79
                                        got one with password. locked backup attached.
                                        Dell Optiplex 7090 tower 11th gen.
                                        ST: F8C1VJ3
                                        thanks...
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12118
                                          #80
                                          ST: F8C1VJ3
                                          thanks...
                                          Unlocked
