I Need a Clean Bios for Logic Board 820-01134-A Pleasee. ! !!!
  • neper
    • Mar 2016
    • 12
    • usa
    Hi, I have a logic Board 820-01134-A and I replaced the PCH because it was in short. When the Unit power on shows and error in the screen and restarts, Please I need a Clean Bios.
  • peste
    • 13573
    • ROMANIA
    Re: I Need a Clean Bios for Logic Board 820-01134-A Pleasee. ! !!!
    post the backup of the original bios.
    • Repdata
      • May 2020
      • 67
      • Deutschland
      Please
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • edward card
        BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
        by edward card
        I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
        Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
        Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
        Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
        10-06-2025, 05:41 AM
      • Yanleb
        LG 60PK550 Logic Control Board EBR63450301
        by Yanleb
        Hi all, I just want to share the repair of my 60PK550-UA TV set.
        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
        C57: 3.30V
        C61:...
        07-20-2023, 12:38 AM
