Hp prodesk 600 g4 DM PC
  • alihomee
    • Dec 2012
    • 1575
    • malaysia
    this pc turns on with no display,,,,,i found two bios chips on mobo so confused which one should flas ...any advice on which bios chip should flash...one is 16mb and other one is 32mb pic is attached
  • peste
    • Dec 2016
    • 12787
    • ROMANIA
    Re: Hp prodesk 600 g4 DM PC
    post the content on both bios chips.
    • malishah83
      • Oct 2015
      • 13
      • Hyderabad
      Re: Hp prodesk 600 g4 MT PC
      Here is my dump file
      • ASB
        • Dec 2020
        • 133
        • Pakistan
        Hp ProDesk 600 G4 Mini Bios Problem.
        Pc was getting powered on giving 3 long & 2 short beeps without ram. I tried to repair its main bios (25Q256) but something went wrong and it damaged 16Mb (25Q128) bios too. Now even with original bios, Pc gives 6 long & 3 short beeps and doesn't power on. Please help to fix these bios or if someone has working bios (16Mb & 32Mb), kindly share. Thanks.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11727
          Re: Hp ProDesk 600 G4 Mini Bios Problem.
          • ASB
            • Dec 2020
            • 133
            • Pakistan
            Originally posted by hoaca388
            Hoaca388, with your bios, pc is back to life but still in the previous state, i.e., 3 long & 2 short beeps but no display with ram. I have checked The processor/ ram & both are ok.
            • ASB
              • Dec 2020
              • 133
              • Pakistan
              Can someone please extract the BIOS RGN file from the bin file in the Hp bios update?
              • ASB
                • Dec 2020
                • 133
                • Pakistan
                  • 20855
                  Open Q22_022300.bin with a hex editor,delete 0 - 21F (length 220) ,next select block 0 - FFFFFF (length 1000000) ,copy and paste into a new file and save.
                  • SomnusDisney013
                    • Oct 2022
                    • 18
                    • Poland
                    Hi, I have an HP 600 G4 minitower computer. The BIOS was probably updated when the processor was replaced. The power went out and now the computer won't start.
                    Is it possible to rebuild? On another BIOS I get a 6 red 3 white or other signal​
                      • 20855
                      Post the PC serial number - https://www.badcaps.net/forum/troubl...before-posting
                      • SomnusDisney013
                        • Oct 2022
                        • 18
                        • Poland
                        serial number: CZC90F960 prodcut no: 2VE73AV
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11727
                          HP ProDesk 600 G4 Base Model Microtower PC
                          • SomnusDisney013
                            • Oct 2022
                            • 18
                            • Poland
                            Thank you for your help. The BIOS did not help in repairing the computer. However, there must still be something damaged in the computer. Only the green LED is lit.
                            • ProAlex
                              • Nov 2024
                              • 6
                              • Ru
                              Please share a working bios dump for HP prodesk 600 g4 DM board F81 DA0F81MB6A0 REV A . There is no image and the usb is not active, it turns off after a minute, it does not show errors only when I remove the memory. The original firmware has damaged both images of the flash chips.
                                • 20855
                                • ProAlex
                                  • Nov 2024
                                  • 6
                                  • Ru
                                  SN: 8CC8500Q8X
                                  But according to the number on the case, I find that this is the Elitedesk 800 g4 dm and this number is written in the firmware, although the F81 board is exactly the same as in the Prodesk 600 g4 dm, I am confused.The computer was given away and said it would not turn on . I cleaned the firmware ME region, now it turns on itself and restarts every 30 seconds the image is not output , the USB keyboard is not active the backlight lights up for a short time .
                                  • ProAlex
                                    • Nov 2024
                                    • 6
                                    • Ru
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11727
                                      HP EliteDesk 800 95W G4 Desktop Mini PC
                                      • ProAlex
                                        • Nov 2024
                                        • 6
                                        • Ru
                                        hoaca388
                                        Thank you very much. I will try.
