Imac A1419- EMC 3070 need password remove
  • joen_d66
    replied
    Originally posted by peste
    Re: Imac A1419- EMC 3070 need password remove
    try..
    thanks..i will to merge with my corrupt bios
  • peste
    replied
    Originally posted by ribar96
    hello people,
    I have locked bios on IMac A1419 can anyone help me?
    post S/N, full name and model, motherboard model, EMC,etc.
  • ribar96
    replied
    hello people,
  • elbtonet
    replied
    Hi I have an imac 27 a1419 emc 3070. no screen showing ,and diagnostic lights shows ,1,2,3 ON and 4,5 OFF think it is a bios issue so Im postin the oem one . Please if u can help me with this one..MANY THANKS
    Also Replaced the LCD screen to test , and still the same issue
  • hardware1
    replied
    Originally posted by shadow225
    would someone kindly unlock this Imac dump?
    Imac A1419 EMC 2834
    Here's your Unlocked file, try it.
  • shadow225
    replied
    Imac A1419 EMC 2834
  • nabilgo
    replied
    try..
    thank you sir it work
  • peste
    replied
    Originally posted by nabilgo
    Any pls can unlock it for me imac a1419 thanks in advance
    try..
  • nabilgo
    replied
  • peste
    replied
    Re: a1419 efi lock help
    Originally posted by leemobile2306
    hi could someone please help me with unlocking this from efi, ive tried rc unlocker but the lock still remains upon reboot
    thanks in advance
    RCUnlocker is for HP only ...
  • leemobile2306
    replied
    a1419 efi lock help
    thanks in advance
  • basic
    replied
    friends i found the problem , in the board are some missing parts which have been damaged when dissasembly imac to flash bios , so now i will take picture of parts which missing on board and maybe i need again help to find parts and to identify
  • peste
    replied
    Originally posted by basic
    not working no turn on
    the bios posted by you is longer..I deleted the password and cut it to the normal value ... 100% it should work ... see that you have no problems writing and reading ... maybe the bios posted it's not ok, because of this what I sent you doesn't work ... or maybe you have problems writing ... send the model of the motherboard and serial number S / N ...
  • basic
    replied
    Originally posted by Maxpower3
    which programmer do you have?
    Did you do several reading and comparison.
    I'm afraid of a corrupted file or bad solders
    superpro 580 u
    soldering is fine 25 years experience
  • Maxpower3
    replied
  • basic
    replied
    Damn, I hope my file has nothing to do with it. I do not think so.
    @ Vesko, Peste an idea?
    Did you try again your original after @Peste file?
    you indicate that it's not turn on
    yes i have try original after @Peste file and your file but same problem
  • Maxpower3
    replied
    hmmm i been flash even the ori file which is came from but same problem
  • basic
    replied
    bad file ,wait another file by a members of forum .
    you have tried just first file ?
    don't test n*2 is useless
  • Maxpower3
    replied
    my friend , after flashing bios now i have problem , LED 1 on logicboard is steady and fan spins then stops - LED 2 blinks
    what can be wrong ..
  • basic
    replied
    With some tools but not export modified file . Must be connected only to apple device for flash directly.
    so I have to search and modify manually.
    Another test with no icloud .
    I am not sure of my files.
    Never tested
