Help me pls. Dell optiplex 3080 clean bios
Attached FilesLeave a comment:
Hello, please can you help me remove password on optiplex 3080 ServiceTag: FCTRQJ3 Bios version: 2.1.1, Bios backup attechedAttached FilesLeave a comment:
Hello all, got a dell 3080 that was going for recycling. Managed to fix it but it is bios locked. Any chance someone can unlock the below?
service tag is:
9NZ9WF3Attached FilesLeave a comment:
tryAttached FilesLeave a comment:
Bios is password locked
Service Tag: JFXP4K3Attached FilesLeave a comment:
Re: Hello, can you help me remove password?
Optiplex 3080 micro Service Tag: JSR4X63
Thanks....Leave a comment:
Password removed.Attached FilesLeave a comment:
Post the required service tag https://www.badcaps.net/forum/troubl...before-posting -
I also need a clean Bios. Any help greatly appreciatedAttached FilesLeave a comment:
I've loose BIOS password. Could you help me to reset? Optiplex 3080 Micro
SERVIGE TAG: 53KWJB3Attached FilesLeave a comment:
https://www.youtube.com/results?search_query=ch341aLeave a comment:
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
by ASBI recieved 2 Dell OptiPlex 7040 MT pcs for repair. One got fixed with clean me bios but the other one didn't work with clean me bios. With original bios, its CPU fan would turn on slowly and after a few seconds start spinning at full speed but when I reprogrammed the chip with tested clean me bios, the CPU fan would start at normal speed and shut down after a few seconds. When I press the power button, the fan spins and then stops again. With original bios, it keeps spinning at full speed. I tried repairing its bios but it didn't work as well. The CPU core voltage (VCORE) is zero in both cases....
by toti24dell precision m4600 laptop
i7 2760qm
8gb ram 750gb HDD
intel hd 3000 integraded and nvidia quadro 2000m
pleasea bear with me english isnt my language and ill try to be as clear as possible
note i live in mexico in a very small town..
thank you.
laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
the brick happened when i was installing win 10 using usb.
used rufus and officia microsoft.iso
it finished copying files from usb...-
Channel: BIOS Requests ONLY!
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
- Loading...
