Bios need for TOSHIBA LX810 6050A257201
  • teckhing79
    • Nov 2020
    • 18
    • malaysia
    Attatch with original file
  • peste
    • 13557
    • ROMANIA
    Re: Bios need for TOSHIBA LX810 6050A257201
    try..
    • dennison flores
      • Apr 2021
      • 22
      • Philippines
      what is the problem?
      • teckhing79
        • Nov 2020
        • 18
        • malaysia
        no display.
        no luck, not the bios problem. have to check again.
        • bondminer009
          Need Bios for Latitude 7650 (No Original / dump bios file)
          by bondminer009
          Good Evening,
          Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
          Thank You
          Salam,
          Three
          11-12-2024, 07:48 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • joshAU
          BIOS file for N550JK (original dump attached)
          by joshAU
          Hi all.
          I'm looking for a BIOS file for an Asus N550JK.
          I have a Asus R552J, which I believe is identical to the Asus N550JK.
          I downloaded the latest BIOS (210) for the R552.
          It is named N550JKAS.210.
          The BIOS file is however only 6mb in size.
          I've read the chip with a CH341A programmer and verified the file.
          That file is actually 8mb in size.
          I'm wanting to remove the BIOS password from this unit.
          It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
          08-09-2022, 08:06 PM
        • adelage
          Merge ECS Z77-H2 bios cap file with original dump
          by adelage
          I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
          03-11-2025, 03:07 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
