need dump for hp 400 g3
  • basic
    • Oct 2017
    • 229
    • 86357289244
    hi friends
    i need working bios dump for hp 400 G3 / ms 7957 ver 1.0
    thanks in advance
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Re: need dump for hp 400 g3
    TRY FROM POST #11
    POSTED BY SMDFlea
    https://www.badcaps.net/forum/showthread.php?p=942791
    if no luck than post your backup bios here
    • basic
      • Oct 2017
      • 229
      • 86357289244
      i will try now but is REV A bios
      but i need REV 1.0 7957 board ..
      also i dont have a backup , is erased all
      • basic
        • Oct 2017
        • 229
        • 86357289244
        Yesss is working a dump from SMDFlea
        THANKS THANKS
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • cekcons
          g1 assassin Rev 1 bios dump - main and backup needed
          by cekcons
          main and backup ic dead so i cant post corrupt bios cause its 01 all over.
          thanks
          01-23-2024, 03:26 AM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • DynaxSC
          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
          by DynaxSC
          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
          11-06-2022, 05:22 PM
