Dan97rmb6d0 rev d bios
  • nabilgo
    • May 2016
    • 303
    • L.A
    Re: Dan97rmb6d0 rev d
    Originally posted by zaraki7777
    this one
    thank you work 100 percent
    • saidcalis
      • Sep 2020
      • Turkiye
      If the power light blinks 7 times and does not work, connect the led cable from the LCD panel to the motherboard, this is not a malfunction.
      • tiamoface
        • Jan 2019
        • 7
        • United Kingdom
        Where is BIOS chip located on this board or what chip IC named please?
        • Mdon
          • May 2019
          • 7
          • Cyprus
          Hello, I have the same issue motherboard DAN97RMB6D0 REV D
          I would really appreciate it if you can send me the relevant BIOS File
          The serial number is 8CC9252L86
          Model Name: 24-f0008nv
          Product ID: 4HC11EA#AB7
            • 21853
            Post your backup
            • Mdon
              • May 2019
              • 7
              • Cyprus
              #26
              unfortunately I downloaded one of the bin files that you posted on thread and wrote on the BIOS without taking a backup!
              • peste
                • Dec 2016
                • 13573
                • ROMANIA
                #27
                try this...
                • Mdon
                  • May 2019
                  • 7
                  • Cyprus
                  #28
                  Thank you. still same issue, 7 white blinks right after plugging in the power supply.
                  Any idea?
                  • peste
                    • Dec 2016
                    • 13573
                    • ROMANIA
                    #29
                    Any idea?
                    did you measure voltages ?? what error code are 7 white lights ??
                    • ramrk
                      • Feb 2019
                      • 155
                      • India
                      #30
                      i need bios DAN97AMB6D0 REV N97A
                      • Rocker
                        • Jun 2022
                        • Chuvashiya
                        #31
                        HELP!!! Where is BIOS chip located on this board or what chip IC named please?
                        • njoi96
                          • Jun 2022
                          • Indonesia
                          #32
                          work sir thank you
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12322
                            #33
                            Usually it is located near the CMOS battery.
                            • muthee254
                              muthe_kenya
                              • Aug 2017
                              • 10
                              • kenya
                              #34
                              This helped me out alot. Thank you
                              • William990
                                • Nov 2022
                                • Naples
                                #35
                                Re: Dan97rmb6d0 rev d bios
                                Hello everybody
                                I have an HP 24-f0005nl which when turned on makes 3 long beeps and 4 short beeps and reading a bit on the web there could be several causes including BIOS corruption. I tried to replace BIOS RAM and battery but nothing to do, I would only have to try with the BIOS. Having no backup of anything and not booting the PC to video at all, is it possible to flash the BIOS in some way?? If so where could I find the BIOS?? Thank you all in advance and sorry for my bad English.
                                Serial Number: 8CC8230JZ3
                                Model: 24-f0005nl
                                Product ID: 4MZ14EA#ABZ
                                Mainboard: DAN97RMB6D0 REV D
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12322
                                  #36
                                  Originally posted by William990
                                  Hello everybody
                                  Model: 24-f0005nl
                                  HP All-in-One 24-f0005nl
                                  • kesmeseker
                                    • Jan 2015
                                    • 121
                                    • turkey
                                    #37
                                    DAN97AMB6D0 REV bios
                                    hi. I need DAN97AMB6D0 REV : D bios .
                                    model :n97a
                                    my bios backup...
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12322
                                      #38
                                      Re: DAN97AMB6D0 REV bios
                                      model :n97a
                                      my bios backup...
                                      HP All-in-One 24-f0048nt
                                      • arkan.c.g
                                        • Nov 2017
                                        • 9
                                        • indonesia
                                        #39
                                        hello guy ..help me please bios aio dan97amb6d0 rev : d
                                        • hardware1
                                          • Sep 2021
                                          • 2948
                                          • N/A
                                          #40
                                          Upload your Original Backup and write your device Serial Number.
                                          all donations are welcome,
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            Today, 04:20 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
