Graphics card Schematics and Boardviews
This is a sticky topic.
  • screety888
    • Aug 2023
    • south africa
    #1281
    Re: Graphics card Schematics and Boardviews
    Look what I found boys I spent last night searching I even went through every page in this thread and now I finally have it.
    Gigabyte gtx960 G1 4gb boardview
    • Bagt2023
      • Aug 2023
      • Cuba
      #1282
      I will be very grateful if someone could share schematic or boardview file for:
      Gigabyte GV-N660OC-3GD rev:1.0 card.
      Thank you for any help.
      • screety888
        • Aug 2023
        • south africa
        #1283
        Best I can do is the 2gb version maybe it will help you
        • k-krzych
          • Aug 2023
          • 35
          • Italia
          #1284
          Hello. Looking for EVGA GTX680 FTW schematics/boardview files. Could anyone help me out please?
          Regards
          Regards
          UPDATE
          the part no is: 04G-P4-3685-B1
          Thanks in advance
          • Bagt2023
            • Aug 2023
            • Cuba
            #1285
            Thank you very much!
            • skidrush
              • Aug 2023
              • South Africa
              #1286
              Hi, I'm looking for a schematic and boardview for my Palit 1050 Ti Dual OC. I have an issue where my screen will turn black and the cards fans will begin to spin intermittently, rapidly switching between high, low and normal fan speeds. The card will sometimes work fine upon resetting the PC or it won't. I decided to visually inspect the card and found what appears to be a burnt fuse. My goal is to use the schematic and boardview to find out what is connected to the fuse on either side and use that information to hopefully find the root cause of my issue. Your help would be greatly appreciated. Thank you.
              Correction, nothing stood out to me during the visual inspection. However I noticed the fuse and tested it using a multimeter in continuity mode.
              • Pankee
                • Aug 2023
                • Mexico
                #1287
                I am looking for a ZOTAC GeForce GTX 1660 Super AMP schematics, one chip burned and i cant find the replacement
                • tomatojoe13
                  • Dec 2020
                  • South Africa
                  #1288
                  MSI N650 GTX V280 Rev 1.0 Schematic
                  • tomatojoe13
                    • Dec 2020
                    • South Africa
                    #1289
                    Does someone have MSI V232 schematic/boardview?
                    N560GTX-M2D1GD5 / 560 GTX
                    • OoVedita
                      • Aug 2023
                      • Brasil
                      #1290
                      Good morning everyone, I need the GTX 1660 Super NB 6G V2-V boardview. which pwm equivalent to the "ALNB 051T" (PS_PEX)?
                      • DynaxSC
                        • Apr 2021
                        • 477
                        • Poland
                        #1291
                        ASUS ROG STRIX B360-I GAMING - Boardview ?
                        Hi, could anybody post BV for ASUS ROG STRIX B360-I GAMING ?
                        • danisenpai12
                          • Aug 2023
                          • Philippines
                          #1292
                          i need schematics for my AFOX GT 730 2gb gpu, i blew a capacitors on it, 3 exactly. I don't know the exact model of capacitors for it to replace.
                          • Oinkypig
                            • Aug 2023
                            • 9
                            Need an rtx 2070 mobile schematic, or better yet an eluktronics max 17 9750h+rtx2070 laptop schematic. I managed to short a resistor near the cpu, and replaced with a 0603 0 ohm resistor. for the last 2 years, all has been fine until recently, black screen audio loop hard reset due to high fluctuations in cpu v-core along with an internal_video_scheduler error under high loads. I need to check 0402 r102 resistor on a schematic for the gpu vram section to measure impedance. Cant tell if its a bad resistor or not, got awfully close to some liquid metal before i got it off the edge of the kapton tape right ontop of r102. right now im reading 3.5 kilo-ohms but most of the resistors surrounding similiar vram memory modules are 4.5kilo-ohms.
                            • danisenpai12
                              • Aug 2023
                              • Philippines
                              #1294
                              Re: Gt 730 voltage reg , burnt
                              Originally posted by przekrent
                              APL1117-ADJ or APL1117-5 - 5V linear regulator.
                              Sir do you by a chance know the schematics for Ninja GT 730 4gb 128 bit?
                              • LeandroRDS
                                • Apr 2019
                                • Brazil
                                #1295
                                Hi, can anyone help with a schematic / boardview for RX 6700XT.
                                • augustusii
                                  • Sep 2022
                                  • 7
                                  Hello, looking for boardview of Gigabyte Radeon 5700 XT. Thanks for any help!
                                  • jermac0711
                                    • Jun 2022
                                    • 74
                                    • Philippines
                                    #1297
                                    do we have a schematic for Gigabyte GV-N960IX-2GD
                                    • nino003i
                                      • Sep 2023
                                      • morocco
                                      #1298
                                      Originally posted by dicky96
                                      And I also have these. One boardview and a couple of GPU ROMS but I thought I may as well post them here anyway
                                      If I get anymore GPU schematics/board views I will post them
                                      i need ASUS Dual GeForceĀ® GTX 1650 schematics
                                      • lolich112
                                        • Sep 2023
                                        • 10
                                        • Deutschland
                                        #1299
                                        Hey. Someone got the schematics for the Palit gtx 750 STORMX 2Gb? I would appreciate it.
                                        • nino003i
                                          • Sep 2023
                                          • morocco
                                          #1300
                                          looking for Asus DUAL-GTX1650-O4G Schematics
                                            Lenovo ThinkPad P53 Mobile workstation P Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad P53 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P53 boardview and P53 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 09:53 AM
                                            Lenovo ThinkPad P73 Mobile workstation P Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad P73 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P73 boardview and P73 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 09:45 AM
