HP Envy Recline 23 Schematic - DA0NZ8MB6F0 REV F
  • jophuttenhuis
    • Mar 2014
    • 4
    • Nederland
    Hi there,
    HP Envy Recline 23 doesn't power up anymore.
    Power supply LED turns of directly after hooking up the plug into the base socket.
    During last usage the back side, top right (near mobo, heatpipes) was really hot.
    Fan was full of dust.
    Disconnected all peripheral connectors (HDD, speakers, HDMI-out, audio, WLAN, etc), only the DCIN cable and FAN cable connected, the power-supply LED still goes out after plugging in the plug into the base.
    Hope you guys have a schematic of motherboard DA0NZ8MB6F0 REV F.
    Or any other suggestion?
  • jophuttenhuis
    • Mar 2014
    • 4
    • Nederland
    Re: HP Envy Recline 23 Schematic - DA0NZ8MB6F0 REV F
    Supplying power to DCIN (PJ1) + on pin1, GND on pin8.
    Power supply is limiting current to 1A @ 3.7V
    Thermal inspection shows PQ17 (Marking: 4439GM, 40232G) heats up really quickly.
    PQ17 seems to be a MOSFET.
    PQ17 (top side) is close to PU19 (bottom side, marking: AS393M-G1)
    Seems to be: Low Power Low Offset Voltage Dual Comparator.
    • jophuttenhuis
      • Mar 2014
      • 4
      • Nederland
      Is there maybe someone who knows a board which has a similar design?
      Or someone who has a similar problem?
      • dammysholove
        • Jun 2017
        • 59
        • nigeria
        Good day
        Please dis u find the schematic or such design??
        • juanmijm
          • Feb 2018
          • 4
          • spain
          hello, I have a computer like this damaged by lightning, it has a couple of burned components near the entrance dc in, specifically r417 and l18
          I leave you an image in case someone can tell me what values they are. thanks.
          • duder
            • Oct 2013
            • 26
            • canada
            Hi - I have one with the same problem. It took me almost 3 hours, but I found PC16 shorted.
            • mo4nis
              • Dec 2018
              • 53
              • maroc
              Hi there,
              board view
              • s22o
                • Feb 2016
                • 3
                • EspaƱa
                R417 = 0 ohm
                L18 = катушка
