need bios for HP-AIO-MODEL-20-C412NH
  • okbalord
    • Jun 2017
    • 204
    • Algeria
    Bios corrupted dan91gmb6d0 rev: D
    i need help to fix it !!!!!
    Ty
    OKBALORD
  • peste
    • Dec 2016
    • 12859
    • ROMANIA
    Re: need bios for HP-AIO-MODEL-20-C412NH
    Try...
    • Alson
      Alson commented
      Editing a comment
      Works for me BID-08432 THAKS
  • okbalord
    • Jun 2017
    • 204
    • Algeria
    Thanks bro for answering but it didn't work
    OKBALORD
      • 20977
      Try this one
      D BEED50 - C0DFEF
      • okbalord
        • Jun 2017
        • 204
        • Algeria
        Originally posted by SMDFlea
        Try this one
        D BEED50 - C0DFEF
        ty bro:::::::::
        not coming on just 7 blink the fan won't spin. but the cpu is worm :!!!!!!
        OKBALORD
        • bekerek
          • May 2014
          • 14
          • Poland
          Did You find a solution? I have same problem?
          • dimah77
            • Sep 2016
            • 147
            • ALGERIA
            Originally posted by peste
            Try...
            BID-08432 working on 20-C412NH
            Thanx a lot
            • okbalord
              • Jun 2017
              • 204
              • Algeria
              no; the costumer take it not fixed
              OKBALORD
              • anujagranuj
                • Aug 2016
                • 6
                • india
                Try...
                Thanks, This is perfect bios, i have tested it with two PCs
                • vickey_vip
                  • Mar 2016
                  • 134
                  • India
                  Try this one
                  D BEED50 - C0DFEF
                  Thanks working tested on hp 20-C418il dan91gmb6d0 rev d
                  • Jasveer5277
                    • Feb 2023
                    • 7
                    • India
                    Try...
                    It's working 100℅ 16mb bios working 100℅ tasted okk
                    • sagarmahule
                      • Jan 2023
                      • india
                      Try...
                      it,s 100% ok tested bios thank you:
                      • jarustay
                        • Feb 2016
                        • 3
                        • peru
                        Hp 20-c410 dan91gmb6d0 rev d
                        • SAFE-TECH
                          • Jun 2022
                          • 12
                          • Nigeria
                          Try...
                          It's working just fine, 100%
                          • kaif8439
                            MOHAMMAD KAIF
                            • Dec 2020
                            • 7
                            • india
                            ty bro:::::::::
                            connect display
                            • FalconPunch
                              Surface Pro X 1876 Bios corrupted
                              by FalconPunch
                              Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                              Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                              08-09-2025, 03:56 AM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • TylerHyde21
                              Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                              by TylerHyde21
                              Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                              I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                              I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                              This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                              06-29-2024, 10:38 AM
                            • Loli Popu
                              DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                              by Loli Popu
                              Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                              12-13-2024, 08:29 AM
                            • Ugur87
                              Need Bios or Help for Corrupted Bios.bin XPlus Series 81
                              by Ugur87
                              Hello
                              ive got a brand new Xplus Series 81 mini Notebook, but its not turning on, my friend take it and make something with it, everthing looks fine , charging , power input perfect , fans spinning but no image, now i read the bios chip with ch341a programmer, i think its corrupted, is there any way to fix a corrupted bios bin ? please help...
                              07-14-2025, 06:41 PM
