Request bios for HP PRODESK 600 G2 DESKTOP MINI
  • vahidsar62
    • Dec 2020
    • 3
    • tehran
    #41
    i need pass unlouk
    Re: Request bios for HP PRODESK 600 G2 DESKTOP MINI
    • peste
      • Dec 2016
      • 12275
      • ROMANIA
      #42
      Re: i need pass unlouk
      https://www.badcaps.net/forum/showthread.php?t=79956
      • bob1101
        • Sep 2017
        • 5
        • lebanon
        #43
        Hello, peste can you help me with this
        I have HP ProDesk 600 G2 Small Form Factor pc
        it gives 5 blinking red lights and 2 fast blinking white lights
        this is my old dump
        thank you
        • santi2019
          • Jun 2019
          • 9
          • españa
          #44
          Originally posted by peste
          try the bios from post # 8.10
          the bios from post # 8.10 has a password, any way to remove the password?
          • santi2019
            • Jun 2019
            • 9
            • españa
            #45
            with hpunlocker.exe you can remove the password.
            bios checked ok, no password
            • Jizzim
              • Mar 2022
              • South Africa
              #46
              Hi Guys I need help with my HP prodesk 600 G2 mini, it gives me an error message on every boot "901-Rear chassis fan failed. There is no rear fan port on the physical motherboard. I've upgraded the cpu when this error started. The latest bios update didn't fix the error. Please help, thanks
              • edrisghavidel
                • Nov 2020
                • 3
                • iran
                #47
                hi this bios has password
                nededd bios 600 g2 sff clean me and not password
                • peste
                  • Dec 2016
                  • 12275
                  • ROMANIA
                  #48
                  post the original bios here and someone will delete your password..
                  • daxx2707
                    • Oct 2022
                    • 3
                    • Venezuela
                    #49
                    Hi peste
                    I have a hp prodesk 600 G2 mini whose bios IC is damaged. I have the replacement IC, but I need the original BIOS. I have tried several posted on this forum, but they don't work. Below is the original BIOS that I managed to extract from the damaged IC.
                    • peste
                      • Dec 2016
                      • 12275
                      • ROMANIA
                      #50
                      Originally posted by daxx2707
                      Hi peste
                      try post #18..
                      • daxx2707
                        • Oct 2022
                        • 3
                        • Venezuela
                        #51
                        try post #18..
                        Thanks but don't work
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11293
                          • Viet Nam
                          #52
                          Check your CH341A.
                          • daxx2707
                            • Oct 2022
                            • 3
                            • Venezuela
                            #53
                            Originally posted by hoaca388
                            Check your CH341A.
                            I changed the software version of the CH341A and it installed fine. But, now it boots the CPU and does not give image. What could be the problem?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11293
                              • Viet Nam
                              #54
                              Try outputting images through other vga ports or HDMI
                              • Nordlig
                                • Oct 2022
                                • 6
                                • Spain
                                #55
                                Hello when I turn on the computer I'm having blinks slow 3 times followed by 2 quick blinks.
                                According to the HP blinking code it means:
                                "The embedded controller has timed out waiting for BIOS to return from
                                memory initialization"
                                Could you help me cleaning it's BIOS please?
                                Thank you
                                • hardware1
                                  • Sep 2021
                                  • 2912
                                  • N/A
                                  #56
                                  Thank you
                                  Here's your new bios file, try it and let me know.
                                  all donations are welcome,
                                  • Nordlig
                                    • Oct 2022
                                    • 6
                                    • Spain
                                    #57
                                    Thank you I'm going to load it tomorrow
                                    Is there a way or it is necessary to extract any information of the original BIOS such as the serial number or other Data before the modified BIOS flashing?
                                    I'm pretty noob in this field
                                    Thank you
                                    • Nordlig
                                      • Oct 2022
                                      • 6
                                      • Spain
                                      #58
                                      Hello hardware1,
                                      The computer is now making 5 long Beeps and 2 short, I think there is a hardware related issue...
                                      • toshinori
                                        • Dec 2022
                                        • Polska
                                        #59
                                        Hello. My g2 400 is bricked. Im trying to reflash bios. But there is a error [Verification error on address: 0x00000089, Device: 0x08 ]
                                        Im using ASPorgrammer and chip is MX25L128...
                                        Any sugestions will be welcome. Thanks.
                                        • peste
                                          • Dec 2016
                                          • 12275
                                          • ROMANIA
                                          #60
                                          remove the chip from the motherboard and stick it on the programmer if you don't have an adapter.. or stick wires between the programmer and the chip. don't use the clip.. you probably don't have firm contact between the programmer and the chip..
                                          • hotcrossedbuns999
                                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                            by hotcrossedbuns999
                                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                            3. I could only locate two chips that look like bios chips. Could someone verify this
                                            01-03-2025, 12:32 PM
                                          • zean
                                            HP ProDesk 600 G5 Desktop Mini bios
                                            by zean
                                            can anybody please help me open my bios so i can adjust my settings and play the game i used to play before, it always appear to have a password i don't even know, i tried entering my desktop password but it won't open and i didn't remember that i put a password onto it
                                            Manufacturer: HP
                                            Product: 8598
                                            Serial Number: PHVUT0A8JDOIDR
                                            Version: KBC Version 08.09.20
                                            please feel free to reply onto me if there's any other information u need to know to unlock it
                                            08-31-2024, 10:18 AM
                                          • SystemFuchs
                                            Need help with BIOS Admin PW for HP ProDesk 405 G6 Desktop Mini PC
                                            by SystemFuchs
                                            Hi there,
                                            I need your help, dumped the BIOS with CH431a controller, but the usual tools are not working because it is a 32MB Bios file.
                                            Serial: 8CC13458H1...
                                            01-28-2025, 02:54 AM
                                          • beBoss
                                            HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                            by beBoss
                                            as noobie to this please excuse my lack of experience.
                                            I am trying to remove a BIOS password from this machine:
                                            HP ProDesk 400 G6 Mini
                                            but so far I still have no success.
                                            I bought CH341 programmer and decided to give it a try.
                                            The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                            I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                            05-30-2024, 12:48 PM
                                          • eric2022
                                            HP ProDesk 405 G6 Desktop mini bios
                                            by eric2022
                                            HELP CLEAN ME
                                            HP ProDesk 405 G6 DESKTOP MINI PC
                                            SNL 8CC152147M
                                            daf92mb26b0
                                            06-18-2024, 02:42 AM
