need optiplex 7010 bios dump
  • djesoric
    replied
    dell Optiplex 7010 micro
    service Tag : GWHQ924
    Pease help me disable absolute. thank you in advance.
  • dhan
    replied
    Originally posted by dhan
    MB: d13_mff_luxor_low 212045-1
    Service Tag: HQBQT34
    Please help,
    unable to toggle absolute persistence, ON GRAYED OUT
    PLEASE disregard, I already figured it out.
    thanks
  • dhan
    replied
    Please help,
  • Jimmykimo
    replied
    Bios setting locked. Dim font and cannot make any changes.
  • danito
    replied
    Originally posted by Jimmykimo
    Hi. anyone can help me on this bios.?
    OptiplexMicro 7010
    DYD9JY3
    What's the problem?
  • Jimmykimo
    replied
    OptiplexMicro 7010
    DYD9JY3
  • hoaca388
    replied
    Originally posted by Kennedy Marf
    Hello Teams my bios is locked, help me please. Dell Optiplex Micro 7010.
    Service Tag: 274SF14
    https://www.badcaps.net/forum/troubl...l-8fc8-patcher
  • Kennedy Marf
    replied
  • redcapangler
    replied
    Thank you hoaca388 - I'm going to review the forum threads that speak to ME file cleaning and VSS2 cleaning.
    For putting into Program mode (factory mode?) is there another thread on that?
  • hoaca388
    replied
    Originally posted by redcapangler
    [USER="391642"]
    Can you tell me what you changed to enable manufacturing mode?
    Did you use my original files to perform the edits or are these unique / new bios?
    Any other changes you made?
    _Yes, I did use your file when edit ,since the file on dell home page has up to 4 bios versions, i don't know which version yours belongs to.
    _I Clear ME your file, why, because of Service Tag, then VSS2, it needs to be cleaned. Finally put it into Program mode.
  • redcapangler
    replied
    hoaca388 - These worked! I'm very interested in learning the steps you took to modify these if you're willing to share.
    Really interested in learning what text strings you used to then identify in Hex where the changes had to be made to the .bin files.
    It looks like you had to modify both files in my case.
    ######### Documentation for Others #############
    For anyone else reading that's newer like myself, these are the steps I took after hoaca388 saved the day with the .bin file edits.
    1. Upload bios to respective chip (in my case the 16mb and 32mb one). I used Neo programmer, checked for detection, and enabled every option on the write (Off protect, Blank Check, verify, write, erase).
    2. After each upload, perform a read and compare to the files uploaded, ensure a match in HxD software using the "Analyses feature"
    3. I put the CR2032 battery back into the motherboard once all clips removed (i still have microwires on my secondary 32mb chip, but wasn't a problem)
    4. I turned the system on, it went through a couple of false starts, maybe two where the fan spun and it turned back off. On the third time the message appeared for "Manufacturing Mode". This allowed me to go into the bios and type the service tag I had saved in. Before exiting (after typing the service tag and hitting agree on warnings) I was able to go to the security section and click the now ungrayed "Absolute" section, checking "permanently disabled". I accepted every warning, rebooted and confirmed it is 100% disabled in the bios after a reboot,.
    Thank you for your help,
    - Brian
  • hoaca388
    replied
    I'm wondering if this is what needs to be performed in my file. hoaca388 i'm stuck on my file. What text string did you search to find the offsets to put the bios into manufacturing mode when uploaded? I modified the "abtState" value and uploaded but still grayed out.
    Try
  • redcapangler
    replied
    Originally posted by hoaca388
    FC AA ---> FC 00
    FD AA ----> FD 00
  • redcapangler
    replied
    Ha! I was typing while tired and created a new country - thanks for catching that.
    Thank you, I attempted to write the file you uploaded. Same issue, it does not prompt me to enter a service tag and once i'm in the bios the Absolute is all grayed out still with "Enable Absolute" selected.
    Any other thoughts on this? Can you tell me what else you changed?
  • peste
    commented on 's reply
    post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • volinakis
    replied
    Here are the three files.
    Two are original
    One is the attempted modification of the 32mb bios.
    1st thing: did Trump change your country name in "Cananda"?
    2nd: with your modification you should be able to check " Disable" or "Permanently Disabled" then hit "Apply"
    If not, try this file:
  • redcapangler
    replied
    Two are original
  • redcapangler
    replied
    I've been browsing these forums and hit a wall on my recent project. I'm requesting Absolute/computrace to be disabled in my bios, I purchased this computer online.
    This is my first time doing this, but I made it far. I'm more curious in knowing what I did wrong to learn vs. just having working bios reuploaded. This is the first time I worked with a CH341a programmer.
    Service Tag: 27BH2Z3
    Motherboard: D3V3H (I think?)
    I successfully extracted both the 16mb bios and the 32mb bios from each chip. I then followed the guides that indicated by finding the text string "abtState" would lead me to the hex code that needs to be edited from "AA553F" to "AA553C". I performed this edit, then wiped the 32mb bios chip and uploaded the new bios. When I went into the bios (at least it didn't brick it!") I still saw that it was enabled.
    Some other posts indicate something like a service tag prompt should have appeared, was there additional edits I need to perform in order to disable Absolute/Computrace outside of the hex code?
    It also appears this hex code was only in the 32mb bios, so I did not upload or change the 16mb bios after I realized this and only modified the 32mb ones.
    Any help with learning /explanation will be greatly appreciated. I'm uploading the original two dumps and the modified dump where I attempted to disable it myself without any luck.
    replied
    https://www.badcaps.net/forum/troubl...23#post1622423
  • dhibubabu
    replied
    Hello teams my bios is locked, Its ADMIN PASSWORD. help me please.
    OptiPlex Tower Plus 7010
    Service Tag: CHTGV04
    Dell PN: KJ2V1CR
    Model : KY0108
    Please Share Any Clear me file or help me to unlock the same file
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
    DELL OptiPlex 7010 OptiPlex 7000 i5-3470 Specification for Upgrade or Repair
    This specification for the DELL OptiPlex 7010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7010 boardview and OptiPlex 7010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
    09-12-2024, 02:20 PM
