Help please need bin file bios Asus h110m-d
  • christian0024
    • Apr 2016
    • 25
    • philippine
    Anyone have back up of bios h110m-d
    I need bin file
    Thanks thanks
    • 22427
    Re: Help please need bin file bios Asus h110m-d
    Download the latest bios from asus support: https://www.asus.com/Motherboards/H1...HelpDesk_BIOS/
    The ful bios you need is 16,384KB (16MB) .The downloaded bios is 16,386KB ,it has a 2KB CAP header that needs removing.
    Download UEFITool: https://github.com/LongSoft/UEFITool..._A55_win32.zip
    Open the bios with UEFITool ,select "Extract Body" ,that wil remove the 2KB header and leave you with the 16,384KB bios .
    • umesh
      • May 2018
      • 13
      • sri lanka
      Thank you so much for your very clear guidance.
      • compaq
        • Aug 2017
        • 4
        • india
        asus h110m-cs rev:1.02
          • 22427
          Off topic,its a different model.You can use the same method as posted in this thread,just find the h110m-cs support page at asus.If you can`t do it then start your own thread
          • by_mex
            • Feb 2014
            • 57
            • turkey
            Thanks for information
            • to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
              by to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
              I have opened the laptop and identified the main BIOS chip...
              10-24-2025, 01:35 AM
            • Sebastian Codrean
              BIOS file for ASUS F542UN laptop
              by Sebastian Codrean
              Hello to all of you! I need help with a BIOS file.
              The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
              So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
              02-20-2025, 10:25 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • caglarec2268
              Asus X515EA Bios File Please
              by caglarec2268
              merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
              Now "please follow the steps below to recover your bios" text remains on the screen
              I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
              laptop model x515ea-bq945w
              s/n: R4N0CV02K527148
              CN:HWFB
              Board model; ASUS X415EA R7.0
              bios chip: GD25Q128...
              11-27-2024, 03:51 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
