MSI G41 MSP 20 schematic or boardview
  • moateez
    • Jun 2014
    • 119
    • algeria
    hello Friends
    ineed schematic or boardviewer for this motherboard
    the problem is no picteur just black screen
    *** ihave replace power supply
    *** replace ram and cpu
    ***with debug card code error is 01 and led (BIOS /RUN/frame/irdy dont power on)
    *** voltage on mosfet of cpu i found 1.19
    *** voltage on mosfet of ram i found 1.65
    *** voltage on Ic Bios i found 3.3
    please help and follow my thread
  • moateez
    • Jun 2014
    • 119
    • algeria
    Re: MSI G41 MSP 20 No Data On screen
    friends somme help
    • piernov
      • Jan 2016
      • 4437
      • France
      Try to flash the BIOS first
      • moateez
        • Jun 2014
        • 119
        • algeria
        i have try it today sir but same probleme
        *** if you have trust file please upload
        • piernov
          • Jan 2016
          • 4437
          • France
          Various MS-7592 versions attached. Same base platform, but cannot find the exact one for G41M-SP20
          • moateez
            • Jun 2014
            • 119
            • algeria
            Thnx bro i will see
            • kadi144
              • Aug 2015
              • 690
              • algerie
              Thanks bro
              • miloud
                • Nov 2021
                • 13
                • algérie
                Thank you
                • PacoGT
                  HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                  by PacoGT
                  hello firends
                  i search the schematic or boardview
                  I have this motherboard, but I can't find the schematic or the boardview.
                  The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                  So the computer doesn't turn on, and the 3V disappears after a few seconds.
                  The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                  The new problem arose after removing the bad chip.
                  3V and 5V remained together,...
                  08-19-2025, 08:25 PM
                • hosain0489
                  Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                  by hosain0489
                  I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                  Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                  If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                  Thank you very much in advance!
                  07-15-2025, 11:20 AM
                • re-atari
                  Gigabyte GA-H110-D3A schematic/boardview needed
                  by re-atari
                  Hello all,
                  Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                  This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                  02-24-2025, 06:45 PM
                • jonyhdtv
                  HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                  by jonyhdtv
                  Looking for schematic and boardview
                  Model: HP ProBook X360 11 G3 EE
                  Serial: SCG9114JG7
                  Motherboard: L43774-601
                  defect: touchscreen doesn't work (touch works on another computer)
                  thanks to all​
                  01-29-2025, 08:16 AM
                • jonyhdtv
                  HP ProBook X360 11 G5 ee schematic and boardview thanks
                  by jonyhdtv
                  HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
                  Model: HP ProBook X360 11 G5 EE
                  Serial: SCG0164QLH
                  Motherboard: L83950-601
                  defect: no POWER
                  thanks to all​
                  01-29-2025, 08:11 AM
