Imac A1418 820-3302-a need help NO POWER
  • ced1298
    Banned
    • Dec 2014
    • 88536598416
    Good day everybody , i have an imac no sign of power on the motherboard
    - Powersupply has 12V an 3V present but the main logicboard doesnt show any 4 LED lights. hoping someone could help me where can i get a diagram and board viewer on this particular model 820-3302-a much appreicated.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Imac A1418 820-3302-a need help NO POWER
    schematic and boardview. Hope it helps.
    • drewski87
      • Mar 2017
      • usa
      Does anyone have a schematic that shows Q4500 init??? all that i get doesnt show this mosfet... 820-3302-A
      • bruce@phoneroom.com.au
        • Jan 2019
        Hi, I have an A1418 8203302A with exactly the same symptoms , did you find and fix the fault? hope you can help thanks Bruce
        • Sergio Kub
          • Jul 2018
          • 161
          • Brasil
          Thank you very much. With the help of the The Bad Cap Forum I got the schematic and solve the Imac 1418, board 820-3302.
          Only the first diagnostic led was on.
          I researched and noticed that was missing source 3.3V S0, IC U7900 was very hot and found short on the out (PP3V3_S0_FET). I applied 3.3V voltage to pin 8 and found that C4100 was heating up. Did the replacement and computer ok.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • ryogadan78
            iMac A1418 - No LED, no power after overvoltage on Ethernet port
            by ryogadan78
            Hi guys, I need your help again.
            I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
            When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
            06-10-2025, 03:49 AM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            03-31-2024, 02:12 PM
