Asrock Z87E-ITX Bios Rom/bin required
  • ScorpioMan86
    • 94
    • South Africa
    Hi Guys,
    i would like to request a working bios dump for Asrock Z87E-ITX motherboard.
    The board starts up and shuts down after 2 seconds without display or beep, when you remove the bios chip it runs for a bit longer.
    I have made a backup of current bios with CH341A software but i cannot write the bios rom files from asrock site directly to the bios chip.
    Thank you
  • ScorpioMan86
    • 94
    • South Africa
    Re: Asrock Z87E-ITX Bios Rom/bin required
    Anyone ?
    • EbrahimSiami
      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
      by EbrahimSiami
      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
      **What I have tried so far:**
      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
      07-02-2025, 02:31 PM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • paulwal
      Updating a BIOS on ASROCK
      by paulwal
      Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
      https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
      I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
      CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
      Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
      It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
      10-02-2023, 04:13 PM
    • what_1282105
      Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
      by what_1282105
      Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
      02-14-2025, 07:27 PM
