ASUS ET2301I REV.1.3 here dump very hard to find it.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Hello comunity, here dump bios for Asus All in One pc.
  • leecooper2
    • Dec 2014
    • fatih
    Re: ASUS ET2301I REV.1.3 here dump very hard to find it.
    thanks worked
    • korsar86
      ASUS X512FF Rev 3.1 Help to find the KBC dump
      by korsar86
      Asus X512FF (X512FLC) REV 3.1
      Help to find the KBC dump for this model.
      The laptop works. but there is a problem, after power off it no longer responds to the power button, that is, you have to reset the battery and it turns on again (autostart).
      There is also no keyboard backlight and the touchpad does not work.
      The multicontroller is responsible for controlling these functions. Before I replace it, I would like to flash it first. thank you
      Attached is a picture of the sticker and the native dump....
      11-06-2024, 02:47 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • kodox
      Asus ExpertBook B1400CB Bios Dump Needed
      by kodox
      need original bios dump, original bios has flashed by other technician before me.
      attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
      unit info:
      Model: Asus ExpertBook B1400CBA-0711A1235U
      S/N: R6NXNZ006657238
      CN: 7F6F
      Mainboard Code: B1500CBA R2.1...
      08-16-2025, 12:20 PM
    • kcp0085
      Request BIOS dump for ASUS FA617NS
      by kcp0085
      Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
      I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
      Specs:
      - ASUS TUF FA617NS-A16
      - CPU: AMD Ryzen 7
      - BIOS chip: Winbond W25Q16JVSIQ (2MB)
      If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
      Thanks in advance!
      05-02-2025, 12:52 AM
    • Tamo Neko
      Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
      by Tamo Neko
      I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
      What Happened:
      I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
      • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
      • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
      What I Need:
      • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
      02-12-2025, 11:29 PM
