imac A132 emc 2309 no power
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this imac a132 no power cannot turn on it happens when i plugged in the outlet then suddenly electricity goes off then when i turn it on again no sign of life so i open it i noticed that when i press the power button i measured power supply there is no 12v but when i pressed power button many times and check again the power supply now there is 12v what could it be the problem on this?bios chip have 3.3v if this is bios corruption can someone share a working dump for this model please.thanks in advance
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: imac A132 emc 2309 no power
    anyone please on this imac a1312 please
    • String2016
      • Nov 2015
      • 2238
      • philippines
      can anyone share the bios for this model IMAC A1312 820-2507-A i need the urgent please. ill try to flash the biod because i check 19v power ok and also 3.3 and 5 volts is present and in bios chip there is 3.3 volts on vcc.
      • String2016
        • Nov 2015
        • 2238
        • philippines
        12v rail are present 3.3v on power button present and 3.3v on bios chip present but cannot power on no lights can anyone have a working dump for this model please share
        • String2016
          • Nov 2015
          • 2238
          • philippines
          anyone can share a working bios for this model please ill try to flash the bios
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            03-31-2024, 02:12 PM
          • ryogadan78
            iMac A1418 - No LED, no power after overvoltage on Ethernet port
            by ryogadan78
            Hi guys, I need your help again.
            I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
            When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
            06-10-2025, 03:49 AM
