Imac 27 820-3298-A boardview
  • inspirim
    • May 2013
    • 282
    • Italy
    i need boardview Imac 27
    main: 820-3298-A
    051-9504-07
    thanks to all
  • mukesh
    • Dec 2013
    • 10
    • india
    Re: Imac 27 820-3298-A boardview
    hi
    • Morganvii
      • Feb 2019
      • 14
      • Mexico
      Do you have available PDF for this Board?
      • piernov
        • Jan 2016
        • 4437
        • France
        • sk3690
          • Jun 2022
          • 8
          Thank you so much.
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
