Asus X99-S TPU Firmware
  • Xorat
    • Jun 2021
    • 5
    Hey there, i currently have a X99-S that is stuck on a VGA LED! I flashed the bios and now i want to flash the TPU chip as well! But searching for the GUID 38715E0A-ECD3-4776-8AC4-7D93510A7468 gave a way to large file 128kb while the chip, the 24c08wp is only a 8kb chip!
    I cant provide the bios that i used or the extracted image from the TPU chip (it wont let me upload files with .bin or .cap) , but i will attach a picture off the content.
    Anyone knows how to get the image for this? I am using a X99-A boardview for reference. It matches but has major differences with the TPU layout!
    Any help would be greatly apreciated!
    • 21841
    post your files in a zip or rar archive
    • Xorat
      • Jun 2021
      • 5
      Good call on that! Here are the files. The .cap that i used to get the bios image that is currently flashed and then also the image pulled from the TPU chip!
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
      • pengamat_hebat
        Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
        by pengamat_hebat
        I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
        Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
        However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
        I also tried applying 3.3V to pin 3, but it still didn't work.
        I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
        03-25-2025, 04:13 AM
      • Jeroentje
        Asus X571GT repair chip replace and tips wanted
        by Jeroentje
        Hi
        I try to repair a asus Asus X571GT (DA0XKTMB8C0) no power no lights.
        I saw a burned (small hole in it) chip (JW10F) proberly a TPS22976DPUR, I removed it, now with power connected the laptop turns on and direct off again, power led and fn will light up.
        I found on a donor lenovo board a G2898KD1U (wa9y), looks the same ..
        Result is still the same, turns on and direct off again, first attempt is with backlight on all other direct attempts are only the power and fn led.
        Could it be the chip is to diffrent to make the laptop work again ?
        04-28-2024, 10:59 AM
      • mferna14
        ASUS TP412F 3.3V Regulator chip gets very hot
        by mferna14
        Hi all., I am working an ASUS TP412F​., motherboard Model TP412FAC R: 2.0. The problem I am facing is the 3.3 buck converter (L8=7J RT6256BGQUF) gets very hot when 19v is applied through DC-in jack. I don't think Schematics or Boardview is availble for this model. The chip get so hot that I can't even take the voltages of the pins. I replaced the chip but the problem is still there, new chip even gets very hot. The input on pin 5, 19v is present. So I removed the Output coil & the chip & checked the voltages on the chip pads which are as below: Please view if any volts seem to be abnormal....
        07-09-2024, 11:57 AM
