ThinkCentre neo 30a 24 Gen 3 - Type 12CE bios
  • Zibbo
    • Mar 2017
    • 204
    • Zimbabwe
    Kindly requesting a bios repair. All-in-one turns on but no display
    LA-L801P
    Serial Number: MP2DX474
  • hoaca388
    Badcaps
    • Jan 2022
    • 12316
    LA-L801P
    Neo 30a 24 Gen 3 Desktop (ThinkCentre) - Type 12CE
    Non clear ME
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • amgat
      BIOS for ThinkCentre M910 Tiny
      by amgat
      I need a BIOS dump for ThinkCentre M910 Tiny.
      The BIOS chip is : Winbond 25Q128JV
      Board : IQ2X0IH ver 1.0
      I was using a chip clip with my xgecu pro which led to a corrupt BIOS dump, and the BIOS chip was since re-flashed with the donor BIOS from this thread:
      https://www.badcaps.net/forum/troubl...nkcentre-m910q
      This donor BIOS is not working in my system (because...
      11-22-2024, 02:06 PM
    • Kentsfield
      Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
      by Kentsfield
      I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
      Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
      I desoldered the flash IC MX25U12872F and dumped the flash.
      I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
      08-04-2025, 07:46 AM
      by Vesko356
      08-11-2023, 03:27 AM
