GWHL2 VER B bios
  • sirzat
    • Jun 2015
    • 28
    • Tekirdag
    GWHL2 VER B bios
    hi
    GWHL2 VER B bios file shared pleas
    original files :
    • 21841
    Originally posted by sirzat
    hi
    original files :
    post the PC serial number and full model information
    • bondminer009
      Need Bios for Latitude 7650 (No Original / dump bios file)
      by bondminer009
      Good Evening,
      Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
      Thank You
      Salam,
      Three
      11-12-2024, 07:48 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • joshAU
      BIOS file for N550JK (original dump attached)
      by joshAU
      Hi all.
      I'm looking for a BIOS file for an Asus N550JK.
      I have a Asus R552J, which I believe is identical to the Asus N550JK.
      I downloaded the latest BIOS (210) for the R552.
      It is named N550JKAS.210.
      The BIOS file is however only 6mb in size.
      I've read the chip with a CH341A programmer and verified the file.
      That file is actually 8mb in size.
      I'm wanting to remove the BIOS password from this unit.
      It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
      08-09-2022, 08:06 PM
    • adelage
      Merge ECS Z77-H2 bios cap file with original dump
      by adelage
      I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
      03-11-2025, 03:07 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
