Need Boardview XFX Speedster RX 6600 XT
  • devol
    • Oct 2024
    • Poland
    I need schematic for XFX RX 6600 XT
    pcb: 210508KLA
    Customer broke 4 capacitors directly at Pcie connector, I need boardview
  • Dextroyd360
    • May 2025
    • 4
    • Venezuela
    did you find it?
    • DynaxSC
      Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
      by DynaxSC
      I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
      I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
      Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
      Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
      05-04-2025, 12:08 PM
      AMD Radeon RX 6600 XT (RX6600XT) Schematic & Board View
      The Radeon RX 6600 XT is a performance-segment gaming graphics card by AMD, launched on July 30th, 2021. Built on the 7 nm process, and based on the Navi 23 graphics processor, in its Navi 23 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6600 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 23 graphics processor is an average sized chip with a die area...
      10-01-2024, 12:10 PM
    • Maciej Skoczylas
      GV-N3060GAMING OC-12GD - boardview for specific revision
      by Maciej Skoczylas
      I have problem with my graphic card GV-N3060GAMING OC-12GD.
      2 smd elements are missing.
      I've already bought a boardview but it's not complete - that specific area is not attached. I tried with different similar models but without success.
      This is my PCB
      And this is screen of boardview
      As you see those missing capacitors or resistors are not on boardview.
      Also i compared every single transistor from boardview to real card and everything is related.
      It seems that this one is like extra.
      Could anyone...
      08-09-2025, 10:26 AM
    • ca-gamer
      MSI GTX 1070Ti problem with PCIE?
      by ca-gamer
      Hi All,
      I have a problem with my 1070Ti.
      9/10 times card fails to post in PCIE x16 socket. When it finally posts it shows random PCIE reading in GPU-Z. Rarely it shows x16, most of the times it will be either x4 or x1, sometimes x8. But still it will crash with BSOD in x16 slot sometimes even after 1 minute and sometimes it will happen after an hour.
      Moving card to x4 PCIE slot improves it. It will post most of the time (I would say 8/10 times) and I can even play games for hours at full speed (I haven't spotted and slow downs in FPS vs x16). However randomly...
      10-27-2024, 11:11 PM
    • AlexWhat
      Acer Aspire 5 A514 LA-M213P REV1.0 BoardView
      by AlexWhat
      Acer Aspire 5 A514 LA-M213P REV1.0 BoardView...
      10-05-2025, 05:02 PM
