Help clear bios password HP Pro A G2
  • kt1998
    • Aug 2024
    • 12
    Hi, I forgot admin bios password
    Please help me remove it
    Desktop HP Pro A G2
    S/N: 4CE92010KJ
    I tried with RCUnlocker but no luck.
    Thanks for the help.​
  • kt1998
    • Aug 2024
    • 12
    there are 2 jumper on mobo and tried both but nothing, still ask for password to access into bios. Look inside bios file seem different than other bios for other HP model. It's an AMD board so maybe it harder to clear password? or the password store on other location?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12408
      Try
      • kt1998
        • Aug 2024
        • 12
        I already edited the original bin file remove block BFF000 to BFF235. Re-flashing it into bios chip. it shows manufacturing mode is unlock prompt when boot up and all S/N, CT, SKU is missing but i can access to bios without entering password. S/N, CT, SKU, F.byte I can locate in backup bin. Using DMI to add these again. but one thing still urgent me is born on date is 00/00/0000.
        Your bios provided i just check and it doesn't have S/N, CT, SKU, F.byte in it.
        Monday I will try it. Because this computer is a company property so I have to be careful .
        BTW: I'm not the one set bios password and forget it just cleaning mistake from others
        • hoaca388
          Badcaps
          • Jan 2022
          • 12408
          Fearture byte : 2U3E3Q3Y5K6E6J6S6a6y7J7M7Q7T7W7d7mbh.A4
          Sku : 7GR85PA#UUF
          Serial : 4CE92010KJ
          Build ID : 18WWVIAD30#SUUF#DUUF
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • CanukTuk
            Beginner Tutorial for using RCUnlocker to remove BIOS password?
            by CanukTuk
            Kinda new to this, so hoping you will all give me a bit of a pass.
            I came to this forum because need to remove the BIOS password on an HP EliteBook 850 G1.
            I understand that I need to dumpt the BIOS to a dump file, process the dump file with RCUnlocker, then write the modified BIN file back to tthe BIOS chip.
            Is there a beginner guide anywhere that describes the entire process for doing this?
            I am reallly in the dark regarding which tool or tools are required to extract the BIOS dump file, then write the modified BIN back to the BIOS chip. The guides I have...
            03-24-2024, 02:54 PM
          • traxformania
            TONGFANG "GM7TG7P" Bios Password Problem?
            by traxformania
            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
            I'm trying to reset my bios without success.
            I tried :
            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
            11-15-2023, 07:32 AM
          • Nopslide
            HP Omen 15-dh0052nf power-on & bios password
            by Nopslide
            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
            04-01-2024, 04:27 PM
          • outsider
            Panasonic FZ-G1 MK5 - BIOS password returning
            by outsider
            Hello
            I removed the BIOS password thanks to the help of one of the friends of this forum.
            https://www.badcaps.net/forum/troubl...61#post3637661
            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
            06-17-2025, 12:51 AM
