ASUS Prime H410M-R (R1.01)
  • itson
    • Feb 2020
    • 8
    • Estonia
    Working bios needed. MB turns on but no picture.
  • SoporteNetFe
    • Aug 2021
    • 121
    • Argentina
    You can download BIOS from ASUS and use UEFI Tool to extract.​
    • Geomih
      Asus Prime Asus PRIME X670-P r1.01X (60MB1BU0-MB0A06) boardview
      by Geomih
      Couldn't find this particular board on badcaps so here it is for safe keeping...
      08-16-2025, 01:52 PM
    • DynaxSC
      Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
      by DynaxSC
      Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
      For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
      06-10-2023, 11:30 AM
    • McChicken77
      ASUS PRIME x470 - PRO schematics and boardview needed
      by McChicken77
      Hello guys I'm new to board repair. I would like to primarily focus on PC boards, so I picked one up, but now can't find any documentation on it. I found one post with boardview on this forum but it is in a .fz format which my freeboardview program doesn't want to open.
      If someone has a PDF of the schematics and the boardview .brd file I would greatly appreciate it.
      Thanks!
      12-19-2024, 02:10 PM
    • FZG
      Asus Prime X370 Pro - Bios needed
      by FZG
      Hello! I recently purchased a used Asus-Prime-X370-Pro Motherboard and need to update the BIOS to achieve compatibility with 3rd gen Ryzen CPUs (BIOS on the board is probably a very early version, my CPU is only supported since BIOS version 5008).
      I extracted the latest .cap file (version 6042) from Asus website by using UEFI-Tool and flashed it back with a CH341 programmer but it didn´t work. The BIOS structure looked quite different from the original recovered BIOS so I guess I have made a mistake somewhere. If anyone could help with providing a flashable BIOS .bin file, that...
      12-19-2022, 01:07 PM
    • RotVik
      ASUS PRIME B550M-A AC weird behavior
      by RotVik
      Hello, I need a little help
      I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
      I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
      05-01-2025, 04:59 PM
