Hi I need bios bin file for 'HP Pro 3190 MT' motherboard.
HP Pro 3190 MT bios
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by valdesonI request the BIOS file for the motherboard som-6867 rev-a1 19a6686701-01 from the brand Advatech.
- Loading...
