I am looking for the BIOS and EC for the ThinkCentre neo 50t Gen 3 11SC-CTO1WW. Could you please provide these from the official manufacturer's website?
ThinkCentre neo 50t Gen 3 11SC-CTO1WW bios
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by amgatI need a BIOS dump for ThinkCentre M910 Tiny.
The BIOS chip is : Winbond 25Q128JV
Board : IQ2X0IH ver 1.0
I was using a chip clip with my xgecu pro which led to a corrupt BIOS dump, and the BIOS chip was since re-flashed with the donor BIOS from this thread:
https://www.badcaps.net/forum/troubl...nkcentre-m910q
This donor BIOS is not working in my system (because...-
by KentsfieldHi,
I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
I desoldered the flash IC MX25U12872F and dumped the flash.
I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...-
08-04-2025, 07:46 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by mnciks11Hello everyone
how to extract hp bios from the official website even though you loose the serial number, and more information.
I don't know where to start, i wanna contribute to the forum and assist more people but im failing to extract the bios from the official website. I can dmi later on my own but extracting it is the problem. Can someone breake it down more easy so that other will understand as well
thank you-
- Loading...
