ThinkCentre neo 50t Gen 3 11SC-CTO1WW bios
  • rukiano
    • Apr 2021
    • 10
    • osaka
    I am looking for the BIOS and EC for the ThinkCentre neo 50t Gen 3 11SC-CTO1WW. Could you please provide these from the official manufacturer's website?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12396
    Post serial number.
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • amgat
      BIOS for ThinkCentre M910 Tiny
      by amgat
      I need a BIOS dump for ThinkCentre M910 Tiny.
      The BIOS chip is : Winbond 25Q128JV
      Board : IQ2X0IH ver 1.0
      I was using a chip clip with my xgecu pro which led to a corrupt BIOS dump, and the BIOS chip was since re-flashed with the donor BIOS from this thread:
      https://www.badcaps.net/forum/troubl...nkcentre-m910q
      This donor BIOS is not working in my system (because...
      11-22-2024, 02:06 PM
    • Kentsfield
      Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
      by Kentsfield
      I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
      Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
      I desoldered the flash IC MX25U12872F and dumped the flash.
      I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
      08-04-2025, 07:46 AM
      by Vesko356
      08-11-2023, 03:27 AM
    • mnciks11
      How to extract hp bios from the official website
      by mnciks11
      Hello everyone
      how to extract hp bios from the official website even though you loose the serial number, and more information.
      I don't know where to start, i wanna contribute to the forum and assist more people but im failing to extract the bios from the official website. I can dmi later on my own but extracting it is the problem. Can someone breake it down more easy so that other will understand as well
      thank you
      11-20-2022, 10:48 PM
