Looking for help with Clean ME for 2017 imac 27" 820-01134
  • grmac5
    • Dec 2020
    • 5
    Can someone please clean this bios dump for me?
  • peste
    • 13550
    • ROMANIA
    read..
    • tommy97
      iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
      by tommy97
      we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
      Any ideas what might've...
      04-20-2024, 04:48 AM
    • 944longdrift
      Help Identifying board components - iMac 2017 21.5
      by 944longdrift
      2017 iMac (Mid 2017) A1418
      I'm not quite sure how this happened but a couple of components got ripped off the board when removing from the Logic Board from the iMac.
      Can anyone help identify them?
      I'll have to do the trace repair on the board before soldering on replacements but would prefer to order the components rather than get a whole scrap logic board off eBay.
      Thank u
      03-14-2024, 11:53 AM
    • mat2k
      iMac 2017 PSU - shorted PFC mosfet
      by mat2k
      I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
      There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
      03-13-2025, 11:31 AM
    • mon2
      In search of T2 rom dump for iMAC 2017 A1862
      by mon2
      Hello all. Have an imac that is not able to create PP1v8_S5 and there are no shorts on the rail. Unable to DFU due to USB not working. Suspecting corruption of the T2 firmware.
      Welcome all suggestions. Thanks.
      08-13-2024, 08:13 PM
    • iZakre
      HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
      by iZakre
      Hello everybody!
      To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
      The thing is that I had installed TeamViewer and could log into the computer...
      02-19-2023, 02:27 PM
