BIOS DAN14TMB6F0 Rev F Dump Hp 27  ​​​​​​​NEED BIOS
  • pooya_pm
    • Jan 2021
    • 259
    • iraq
    NEED BIOS​
    • 21896
    NEED BIOS
    It is much easier if you type and post the serial number.Did you check your picture its upside down. Options to view the serial in the picture are: 1: stand on your head to view it . 2: Download the picture,rotate it using software,then read then type out .
    Please read the rules again, if you have a bios backup post it . https://www.badcaps.net/forum/troubl...before-posting
    • pooya_pm
      • Jan 2021
      • 259
      • iraq
      SN: 8CC2100XDC
      HP 27-DP1048ur
        SMDFlea commented
        Editing a comment
        Do you have a bios backup ?
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • greelidd
      K6604J Vivobook RTX 4070 BIOS Dump Request
      by greelidd
      Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
      Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
      09-01-2025, 06:14 PM
    • TacticalFahrrad
      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
      by TacticalFahrrad
      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
      06-30-2025, 04:09 AM
