Schematic and BoardView for Asus ROG Crosshair VIII Hero Wi-Fi X570
  • ITnet
    ITnet
    • Nov 2023
    Hi Guys!
    Greetings!
    Does anyone have the Schematics for a Asus ROG Crosshair VIII Hero Wi-Fi? I need the PDF with the specs also.
    Thank you for your help!
  • C0dR
    ASUS ROG Crosshair VIII Hero Schematics
    by C0dR
    I am currently trying to repair my own mainboard ASUS ROG Crosshair VIII Hero with a defective Power regulator chip. I have already soldered off the Chip (ASP1405 / IR35201) on the backside of the mainboard but during that process i knocked off some of the resistors around it and now my problem is I don't know what resistor goes where. Does anyone has the Schematics of that board or at least of the area around the chip (I have found images of it https://www.techpowerup.com/review/a...pwmcontrol.jpg) but there are no values written on the...
    12-13-2023, 08:43 AM
  • C0dR
    Asus Crosshair VIII Hero no VCPU, Error Code 00
    by C0dR
    I am currently working on my Crosshair VIII Hero mainboard on which a GPU short occured after which the mainboard would not turn on again. I suspected the VRM Controller (IR35201) and soldered it off. After that the board turned on again, obviously without providing voltage to CPU etc. I soldered a new IR35201 on it but it seems like the board still don't want to boot correctly. LEDs etc. turn on normally and after I press start button the power supply turns on fully and stays on, so I guess no shorts. Also nothing gets really hot. The error code shows code 00 and I measured VCPU and it was 0...
    09-22-2024, 11:15 AM
  • ShadowAi
    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
    by ShadowAi
    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
    03-15-2024, 10:46 AM
  • Lamer13
    Asus Crosshair VIII Hero (Wi-Fi) - need TPU firmware
    by Lamer13
    Tpu doesnt turn on vcore EN. Its flash is 256kb - 25q20ct, not the ordinary 64kb. Internet suggests to extract body from GUID 38715E0A-.... But the body is 64kb.... Need the tpu firmware and the corresponding mainbios version Thanks
    11-30-2024, 04:59 AM
