Asus Crosshair VIII Hero no VCPU, Error Code 00
  • C0dR
    • Sep 2023
    • 15
    I am currently working on my Crosshair VIII Hero mainboard on which a GPU short occured after which the mainboard would not turn on again. I suspected the VRM Controller (IR35201) and soldered it off. After that the board turned on again, obviously without providing voltage to CPU etc. I soldered a new IR35201 on it but it seems like the board still don't want to boot correctly. LEDs etc. turn on normally and after I press start button the power supply turns on fully and stays on, so I guess no shorts. Also nothing gets really hot. The error code shows code 00 and I measured VCPU and it was 0V. So I it seems something is wrong with the CPU Voltage supply. Since I changed the IR35201 I tested some ports around it. There is some serial data at SM_DIO so I guess superIO chip also works? But the PWM pins only stay at solid ~3V, no switching or anything, sense pins stay low and it seems the IR35201 is just not turning on the VRMs. Is there anything I might check or is the IR35201 dead again? I read its very temperature sensitive, might I have grilled it again? I would like to check everything before considering chaning the chip out again since its not very cheap and I have already ruined the board around it (ripped of pins i have reconstructed with wire )
    Might provide some pictures if needed.
  • Herbs n spices
    • Jan 2021
    • 34
    Unfortunately the IR35201 needs to be programmed with IR POWERCENTER GUI​, or you must take it from another board with the same power configuration. See this post: https://www.badcaps.net/forum/troubl...xii-hero-wi-fi
    • C0dR
      • Sep 2023
      • 15
      ohhh ok I see. well that explains why it does nothing. So it seems I am very much screwed unless I find a defective board or ASUS sends over the profile...☠
