Asrock h470m-hdv bios
  • GINOVI
    • May 2021
    • 6
    • peru
    Hola ... por favor alguien que tenga el archivo BIN del BIOS para la Asrock H470M-HDV .. Muchas Gracias.
    Hello... please someone have the BIOS BIN file for the Asrock H470M-HDV.. Thank you very much.
    • 21022
    Re: Asrock h470m-hdv bios
    Get the bios from Asrock support,download the Instant flash version
    https://www.asrock.com/mb/Intel/H470...index.asp#BIOS
    Extract from the zip file then rename the file extension from the number to bin ,for example H47MHDV1.12 to H47MHDV1.bin
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • paulwal
      Updating a BIOS on ASROCK
      by paulwal
      Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
      https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
      I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
      CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
      Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
      It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
      10-02-2023, 04:13 PM
    • nolaryie
      BIOS .bin file for ASRock B450M Steel Legend
      by nolaryie
      Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
      I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
      Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
      If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
      Thank you!
      08-06-2025, 12:01 PM
