Asrock fatal1ty B85 killer bios need
  • sy_sanyo
    • May 2019
    • 9
    • viet nam
    i have a mainboard Asrock fatal1ty B85 killer rev 1.01 .Please share me original
    bios .
    Thanks all.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11738
    Re: Asrock fatal1ty B85 killer bios need
    bios .
    Thanks all.
    Fatal1ty B85 Killer
    • Grucha98
      Asrock Fatal1ty B450 Gaming-ITX/ac wont boot, cpu phases turn off after a few seconds. Bios?
      by Grucha98
      Hi I'm working on that asrock motherboard. It had shoted mosfet on cpu phase(changed) and 1 cap on bottom side(changed). Led driver is probably shotted too because voltage on one leg of this chip is 0.5v to 5v (its in loop rising and falling) its's RT7905 and i cant find datasheet :/ But its only led driver so mb should work without it. When i desolder it on the same leg is 5v all the time.
      If i start mb on all cpu phases is 1v1 for a few seconds only. Other voltage are present. So i tried to flash bios with the newest on official site and it doesnt help. Its not normal extension...
      01-19-2025, 03:40 PM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • paulwal
      Updating a BIOS on ASROCK
      by paulwal
      Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
      https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
      I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
      CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
      Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
      It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
      10-02-2023, 04:13 PM
