Acer predator PO3-630 D19W6 bricked BIOS
  • bvu
    • Jul 2023
    • 19
    Hi, Sorry I know I replied in a wrong place, because I can't create a new thread for some reason.
    I have a bricked BIOS for this desktop,
    Model: PO3-630
    SN: DGE2CAA00B143005EE30
    Please fix the bios with the proper DMI + Windows licensed key.
    BIOS chip: XMC QH256BKLQ
    BIOS dump is attached.
    Again, I'm sorry for posting in wrong place, if you have the admin power, please forgive me and move my post into correct place. Thanks in advance!
  • hardware1
    • Sep 2021
    • 2936
    • N/A
    Re: Acer predator PO3-630 D19W6 bricked BIOS
    Model: PO3-630
    Here is your new BIOS, try it and let me now.
    Next time remember to mention the device issue.
    Serial Number: "DGE2CAA00B143005EE3000"
    all donations are welcome,
    • bvu
      • Jul 2023
      • 19
      Thank you so much for your effort, I thought no one could do it since this model is not quite common. I will for sure let you know in the future.
      • thizz
        • Oct 2023
        • 13
        Bump, sorry if not allowed. Did this work for you? I'm in the same position nephews pc got bricked i believe I get 2 beeps when computer is started 1 long and 1 short as well as nothing showing on the display. Just ordered a flashing kit. Where is the bios chip located? I can barely read the numbers listed on the chips
        • thizz
          • Oct 2023
          • 13
          Acer predator PO3-630-D13 Bricked Bios
          Hello any help is appreciated I have a bricked BIOS for this desktop,
          Model: PO3-630-D13
          SN: DGE2GAA00A204019393000
          BIOS CHIP: MXIC25L1006E
          Bios dump attached although im not 100% sure that I did that right.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11798
            Re: Acer predator PO3-630-D13 Bricked Bios
            Model: PO3-630-D13
            Backup bios file corrupted or wrong chip.
            • thizz
              • Oct 2023
              • 13
              Thanks, do I need to try to get the dump again? There are some more numbers after that on the chip that I cant read due to white paint on it
              • hoaca388
                Badcaps
                • Jan 2022
                • 11798
                Choose another chip, this one is not the bios chip.
                • thizz
                  • Oct 2023
                  • 13
                  Could MX25L25673gmi-08g be it then? That one is 16 pin. PC has a black display. 1 long beep followed by one short beep and cant get into bios.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11798
                    Looks like that's it.
                    • thizz
                      • Oct 2023
                      • 13
                      Ok thank you! Am I ok to solder wires on the board still connected to the motherboard or should I get a SOP16 to DIP8 Flash Clip to connect to my ch341a to get the bios dump? Sorry for all the questions
                      • thizz
                        • Oct 2023
                        • 13
                        Nevermind actually was about to try soldering jumpers to the chip to attach to the ch341a but im not experienced enough. Ordered the soic16 clip and will attached bios once I receive it!
                        • thizz
                          • Oct 2023
                          • 13
                          Bump, was able to get the chip off with a hot air rework station and connected to ch341a with jumpers.
                          Model: PO3-630-D13
                          BIOS CHIP: MX25L25673G
                          Thank you for your help!
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11798
                            Model: PO3-630-D13
                            Predator PO3-630
                            • thizz
                              • Oct 2023
                              • 13
                              Predator PO3-630
                              Thank you!!!
                              I just erased and wrote the new file to the IC. Is it normal to still have a lot of F's or did I do something wrong? Just double checking before i try getting the chip back on the motherboard.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11798
                                Thank you!!!
                                It's a complete bios file, you just need to use it
                                • thizz
                                  • Oct 2023
                                  • 13
                                  Ok thank you! Will report back once i get the computer back together.
                                  • thizz
                                    • Oct 2023
                                    • 13
                                    So update, I got it all put back together and nothing happens at all now. Prior to updating bios chip it would turn on automatically when plugged in beep twice and led lights would go on. Now all I see as a sign of life is the Ethernet port lights up on the back and nothing else. Any idea what I messed up?
                                    • ethics
                                      • Oct 2016
                                      • 39
                                      all FFFFF's is blank
                                      load valid bios file and write it to chip....
                                      • thizz
                                        • Oct 2023
                                        • 13
                                        It wasnt all F's but a few rows had F's
