Lenovo Ideacentre B340 ( CIH77S V1.0 ) schematic
  • Bonzas
    • 474
    • Indonesia
    Hi there,
    I need help, maybe someone have schematic for this board and want to share here ?
    thank you
  • Bonzas
    • 474
    • Indonesia
    Re: Lenovo Ideacentre B340 ( CIH77S V1.0 ) schematic
    Nevermind, i got this
    • tony42
      • Mar 2020
      • 5
      • Slovakia
      Hey that was just in time.
      I have one board on the table, which is not posting.
      It just spins the fan for one second.
      I searched for shorts, none found.
      Then I measured voltages (only spikes, as it turns on only for short time) and found that on the chip NCP5212 - I have enable signal, I have power I have ground, but I do not have PGOOD signal.
      I measured also driver high and driver low. Driver high is missing. It is not shorted to gnd. I assume, that NCP5212 is wrong and needs to be replaced.
      I ordered two from China.
      Now I am waiting.
      I downloaded your schematics and I see that NCP5212 is responsible for CPU_VTT, and without it, CPU will not get the power.
      Thank You for the schematics.
      • Bonzas
        • 474
        • Indonesia
        Now I am waiting.
        Just as an advice, before you going too far . Make sure all output voltage on APL5920 & APL5930, on this series ( CIH61S & CIH77S motherboard ) those IC's common problem. I got 2 board this week CIH77S, both won't turn on. 1 board short on 3.3V and the other short on 1.05 ME.
        • tony42
          • Mar 2020
          • 5
          • Slovakia
          Hi again, today I received new NCP5212 chip from ali.
          I quickly installed new part and the board is working.
          So - this is another possible failure - missing signal driver high.
          Anton
