MSI B550 Tomahawk no SPI_CLK
  • McWhitePink
    • Apr 2023
    • 94
    Hi guys,
    I have two same boards, does power on, but stuck in CPU check light,
    measured the BIOS signals, found SPI_CLK has no signal, such that all other input and output doesn't have signal.
    I checked there is no broken wire from BIOS ROM chip to CPU.
    What other thing can I check?
  • baas62
    Burnt resistor MSI B550 Tomahawk Max
    by baas62
    Hello everyone
    I have an MSI B550 Tomahawk Max Wi-Fi motherboard that has burned out components. See photos below.
    I tested the rest of the board, and everything seems to be working properly and stable. I tested it in-game with a 1650 GPU, just in case, and in Cinebench.
    I didn't install an NVME SSD on the first port but only a sata 6gb classic 2.5 inch ssd
    I checked the warranty on the MSI website, and the board is still under warranty until May 2026, but unfortunately I don't have the receipt to request an RMA.
    Is there anyone...
    Today, 01:38 AM
  • limcc
    MSI Tomahawk B550 no beep
    by limcc
    I have a Tomohawk B550 that die suddenly. No BSOD, no weird sign or no POST/boot just a day before it happened. Fans are spinning, BIOS had flashed several times, CMOS cleared, battery removed, etc. CPUs--5600 and 3700X were tested working on 3 other boards--Aorus X570/Auros B550M-Pro-P/TUF X570, so as the PSUs--RM650x/HX650 , as well as the DRAMs, all components are tested working. The only indicator it show was DRAM LED kept lit up, no beep. The same symptom also happen on my 9 years old TUF X99 board but thats another topic, probably due to age.
    Today I bring out the board to check...
    11-16-2024, 12:27 PM
  • Zakyn
    MSI MAG B550 TOMAHAWK - CPU error, boardview REQ
    by Zakyn
    Hi, I've MSI MAG B550 TOMAHAWK, which stuck on CPU error (red EZ debug LED is on).
    1. I've tried to flash BIOS from USB with no success (stuck on red LED blinking).
    2. No component is overheating.
    Does anyone have boardview of this mobo? I would like to trace the problem, but without boardview is pretty hard task. Thanks for any help.
    09-05-2023, 05:01 AM
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
