Asrock fm2a75m-dgs rev 2.0
  • jojo2312
    • Feb 2020
    • 18
    Hi,all
    Need bios bin for this mainboard.Dont have the original bin.
    I take the rom on Asrock site-fm2a75m-dgs rev 2.0,but programmer said :
    file lenght is larger then chip capacity.
    Thx.
    • 21186
    Re: Asrock fm2a75m-dgs rev 2.0
    Originally posted by jojo2312
    Hi,all
    Thx.
    https://www.asrock.com/mb/AMD/FM2A75M-DGS/#BIOS
    Use a hex editor and delete offsets 0 - FFF or Use UEFITool to remove the 4kb CAP header. https://github.com/LongSoft/UEFITool..._A55_win32.zip
    Open the bios with uefitool, right click on AMI Aptio Capsule, Extract Body .
    • jojo2312
      • Feb 2020
      • 18
      Thx it works
        • 21186
        Thx it works
        You`re welcome
        • Michael Angelo Dorio
          Wanderer
          • Feb 2025
          • 11
          • Philippines
          Hello, I have a question here. Will this remove the BIOS admin password once re-flashed? Tests done to clear CMOS, jumper etc. enter blank password and previous password too. I can only see code: D8 sometimes after failing 3x.
          invalid password system stop emergency code
          It didn't return any generated code, I suspect this is already corrupted.
          BOARD: FM2A75M-DGS R2.0 For Desktop.
          • peste
            • 12959
            • ROMANIA
            post S/N, full name and model, etc.
            post the original contents of the bios chip..
            • rockman97
              Need BIOS dump for ASROCK FM2A55M-VG3
              by rockman97
              Hello guys,
              I am struggling to find bios BIN file for ASROCK FM2A55M-VG3 (i had the normal VG3 not the VG3+)
              When i download from official website, and put that in EZP2019+ programmer software it says ''FILE LENGHT, BEYOND RANGE OR IT WILL BE IGNORED''
              That means that file i downloaded is larger than chip says, even tho chip is 8mb and file is 8mb.
              It has the Winbond 25Q64FVAIQ chip what i need to select the prgoram?
              I created a backup but when i rewrite its not work.
              08-23-2025, 04:31 PM
            • Exim
              ASRock N100M, no picture no boot, but semi-alive
              by Exim
              Hi guys,
              I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
              ASRock N100M special features:
              - CPU soldered to board, small Intel 12th gen
              - iGPU
              - four POST LEDs
              Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
              I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
              Symptoms:
              - no picture/signal on any of the display connectors,...
              04-01-2025, 02:36 PM
            • MasterCap
              What IC does AsRock usually use to make the PWM signals for GPU fans ?
              by MasterCap
              I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
              Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
              But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
              12-28-2024, 08:42 AM
            • nolaryie
              BIOS .bin file for ASRock B450M Steel Legend
              by nolaryie
              Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
              I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
              Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
              If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
              Thank you!
              08-06-2025, 12:01 PM
            • khanhtq0
              Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
              by khanhtq0
              I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
              I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
              I suspect the original Intel ME and descriptor...
              08-06-2025, 02:14 AM
