ACER B75H2-AM working bios need
  • bruce35
    • Mar 2022
    • 44
    • turkey
    ACER B75H2-AM working bios need.no screen
    thanks
    • 22030
    Re: ACER B75H2-AM working bios need
    thanks
    PC model number ? , PC serial number ?
    • bruce35
      • Mar 2022
      • 44
      • turkey
      ok
      MODEL acer veriton m4640g
      SERIAL NUMBER DTVNDEM0116070142F1800
      • peste
        • Dec 2016
        • 13691
        • ROMANIA
        ok
        try..
        • bruce35
          • Mar 2022
          • 44
          • turkey
          Originally posted by peste
          try..
          not works.thanks
          • bruce35
            • Mar 2022
            • 44
            • turkey
            try..
            ok i am 5 mınute and screen ok.very thanks
            • anton60
              • Oct 2024
              • 3
              ACER B75H2-AM working Bios please for my
              Veriton 4620
              DTVE2EG01423700DB51800
              • anton60
                • Oct 2024
                • 3
                Hello is this Forum dead !?!😟😞
                  • 22030
                  Not quite
                    • 22030
                    Veriton 4620
                    Post your bios backup.
                    • anton60
                      • Oct 2024
                      • 3
                      Ok here is it.
                      I can not booting 😔.
                      • koonpha
                        • Nov 2025
                        • thai
                        Thank you
                        • titomno2
                          Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
                          by titomno2
                          Hi guys,
                          On motherboard ACER AN515-52 type LAF951P.
                          I fixed issue with not starting computer (it was the PQ201 component not working properly).
                          But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
                          Basically some HDD spin but are not detected by the bios.
                          Already tried following:
                          checked the 4 data lines
                          #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
                          #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
                          07-28-2024, 08:30 AM
                        • aico60
                          Acer Nitro 5 AN515-46 DMI not working
                          by aico60
                          I am working on an Acer Nitro 5 AN515-46, board HH51R LA-M002P Rev: 1A with an AMD CPU and Insyde Bios rev 5.
                          Short issue description: BIOS does not recognize any of the DMI data.
                          History of the laptop:
                          The seller of the laptop said that it shut down during a BIOS update.
                          I bought in in a condition where it turned on but did not post.
                          While waiting for my RT809F to arrive, I tried to perform a Crisis recovery, which messed up the EC firmware, so... the laptop stopped even turning on. Power and Charging LEDs didn't work either...
                          05-06-2025, 08:44 AM
                        • String2016
                          Acer Predator PH315-52 no display/black screen problem - need working bios please.
                          by String2016
                          I need a working bios on this acer predator
                          MODEL:ACER PREDATOR PH315-52 54KC
                          S/N:NHQ54SP00A024028992600
                          SNID:02401039326
                          Attached is the original bios no display problem black screen keyboard lights on...
                          10-10-2023, 06:00 PM
                        • ebyte64
                          Bios request for Acer P214-52-58CH
                          by ebyte64
                          Good day.
                          I would like to request a bios for the following laptop?
                          Model: Acer P214-52-58CH
                          Model No: N19Q7
                          S/N: NXVLHE0H11204BA27600
                          SNID: 11201936276
                          Symptoms: Laptop powers on but no picture on screen.
                          I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
                          09-25-2024, 05:59 AM
                        • verniumEN
                          Acer Extensa 15 EX215-23-R7NG - BIOS, badly need help :(
                          by verniumEN
                          My laptop model is EX215-23-R7NG
                          BIOS chip XM25QU128C
                          Here is my original bin file, as well as how the BIOS chip looks like
                          My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
                          Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...
                          04-21-2025, 02:31 AM
