ACER B75H2-AM working bios need
  • bruce35
    • Mar 2022
    • 44
    • turkey
    ACER B75H2-AM working bios need.no screen
    thanks
    • 21850
    Re: ACER B75H2-AM working bios need
    thanks
    PC model number ? , PC serial number ?
    • bruce35
      • Mar 2022
      • 44
      • turkey
      ok
      MODEL acer veriton m4640g
      SERIAL NUMBER DTVNDEM0116070142F1800
      • peste
        • 13567
        • ROMANIA
        ok
        try..
        • bruce35
          • Mar 2022
          • 44
          • turkey
          Originally posted by peste
          try..
          not works.thanks
          • bruce35
            • Mar 2022
            • 44
            • turkey
            try..
            ok i am 5 mınute and screen ok.very thanks
            • anton60
              • Oct 2024
              ACER B75H2-AM working Bios please for my
              Veriton 4620
              DTVE2EG01423700DB51800
              • anton60
                • Oct 2024
                Hello is this Forum dead !?!😟😞
                  • 21850
                  Not quite
                    • 21850
                    Veriton 4620
                    Post your bios backup.
                    • anton60
                      • Oct 2024
                      Ok here is it.
                      I can not booting 😔.
                      • titomno2
                        Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
                        by titomno2
                        Hi guys,
                        On motherboard ACER AN515-52 type LAF951P.
                        I fixed issue with not starting computer (it was the PQ201 component not working properly).
                        But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
                        Basically some HDD spin but are not detected by the bios.
                        Already tried following:
                        checked the 4 data lines
                        #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
                        #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
                        07-28-2024, 08:30 AM
                      • aico60
                        Acer Nitro 5 AN515-46 DMI not working
                        by aico60
                        I am working on an Acer Nitro 5 AN515-46, board HH51R LA-M002P Rev: 1A with an AMD CPU and Insyde Bios rev 5.
                        Short issue description: BIOS does not recognize any of the DMI data.
                        History of the laptop:
                        The seller of the laptop said that it shut down during a BIOS update.
                        I bought in in a condition where it turned on but did not post.
                        While waiting for my RT809F to arrive, I tried to perform a Crisis recovery, which messed up the EC firmware, so... the laptop stopped even turning on. Power and Charging LEDs didn't work either...
                        05-06-2025, 08:44 AM
                      • String2016
                        Acer Predator PH315-52 no display/black screen problem - need working bios please.
                        by String2016
                        I need a working bios on this acer predator
                        MODEL:ACER PREDATOR PH315-52 54KC
                        S/N:NHQ54SP00A024028992600
                        SNID:02401039326
                        Attached is the original bios no display problem black screen keyboard lights on...
                        10-10-2023, 06:00 PM
                      • ebyte64
                        Bios request for Acer P214-52-58CH
                        by ebyte64
                        Good day.
                        I would like to request a bios for the following laptop?
                        Model: Acer P214-52-58CH
                        Model No: N19Q7
                        S/N: NXVLHE0H11204BA27600
                        SNID: 11201936276
                        Symptoms: Laptop powers on but no picture on screen.
                        I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
                        09-25-2024, 05:59 AM
                      • verniumEN
                        Acer Extensa 15 EX215-23-R7NG - BIOS, badly need help :(
                        by verniumEN
                        My laptop model is EX215-23-R7NG
                        BIOS chip XM25QU128C
                        Here is my original bin file, as well as how the BIOS chip looks like
                        My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
                        Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...
                        04-21-2025, 02:31 AM
