HP AIO 27-dp0188qe bios corrupted
  • waynecg
    • Apr 2023
    • 5
    • N/A
    Here's your new bios file, try it and give me the results.
    Hello, my HP AIO 27-dp0188qe bios corrupted, I can not find the bios file from hp website. could you pls help to rebuild it? The model is similar as HP 200 G4 22 All-in-One PC (7WX26AV) only processor is i7 10510U. pls I need your help, thanks.
    • 20782
    Re: HP AIO 27-dp0188qe bios corrupted
    try this one
    • waynecg
      • Apr 2023
      • 5
      • N/A
      Originally posted by SMDFlea
      try this one
      Hello, thanks a lot!
      I flashed via programmer, it doesn't wok, after power-on, power led always on, no display, no speaker sound.
        • 20782
        Was it the same with your original bios
        • waynecg
          • Apr 2023
          • 5
          • N/A
          AIO 27-dp0188qe has i7 10510U, HP 200 G4 22 All-in-One PC (7WX26AV) are i3 or i5 (10110U or 10210U). I am not sure whether is because of different of processor that cause the black screen?
            • 20782
            If the attached bios doesn`t work youve got some other problem,check all harware.
            • waynecg
              • Apr 2023
              • 5
              • N/A
              Hello, good news that bios.zip is better than 086F8,zip, the back light of display is on, CAPS lock key and num lock key have response. as no display from both hdmi and screen, I'm not sure whether bios is able to load or not, but it can reboot by ctrl+alt+del. Hardware should be okay, any suggestions?
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • Loli Popu
                DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                by Loli Popu
                Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                12-13-2024, 08:29 AM
              • Ugur87
                Need Bios or Help for Corrupted Bios.bin XPlus Series 81
                by Ugur87
                Hello
                ive got a brand new Xplus Series 81 mini Notebook, but its not turning on, my friend take it and make something with it, everthing looks fine , charging , power input perfect , fans spinning but no image, now i read the bios chip with ch341a programmer, i think its corrupted, is there any way to fix a corrupted bios bin ? please help...
                07-14-2025, 06:41 PM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • oragano
                ASUS ex-b250-V7 motherboard bios corrupted - by me
                by oragano
                hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                10-17-2024, 02:53 AM
