Need bios, Hp 440 g6 All in One
  • tahahey
    • Dec 2019
    • 15
    • Turkey
    Hello, I need this bios pls. thks.
    sansa-6050A3161901-MB-A01 (A1)
    SANSA-U & SANSA-G A
    Original backup file
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Re: Need bios, Hp 440 g6 All in One
    SANSA-U & SANSA-G A
    I think you posted the EC Chip, but we need your Main Chip, it could be 32MB.
    Also confirm if that your Serial Number or not: 8CN052003B.
    all donations are welcome,
    • tahahey
      • Dec 2019
      • 15
      • Turkey
      i think you posted the ec chip, but we need your main chip, it could be 32mb.
      Also confirm if that your serial number or not: 8cn052003b.
      sn: 8cn0510hp0
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        sn: 8cn0510hp0
        Here's your New Bios, try it and give me the results.
        Your Serial Number is correct (8cn0510hp0), but the one in your Backup is (8CN052003B) and it's correct also.
        • Nivosysknr
          Nivosysknr commented
          Editing a comment
          thankzz ...its working fine
      • tahahey
        • Dec 2019
        • 15
        • Turkey
        I've tried, but the problem remains the same. thank you for helping
        • walid1992
          • May 2016
          • 36
          • tripoly
          Hello, I need this bios Hp 440 g6 All in One
          i dont hane bakup
          pleees
          main and EC Chip
            • 21853
            i dont hane bakup
            pleees
            main and EC Chip
            Post the PC serial number - https://www.badcaps.net/forum/troubl...before-posting
            • walid1992
              • May 2016
              • 36
              • tripoly
              Originally posted by SMDFlea
              ok Tomorow i will send SN
              • walid1992
                • May 2016
                • 36
                • tripoly
                serial numbers
                • m1ch43lzm
                  Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                  by m1ch43lzm
                  Hi everyone
                  I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                  Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                  Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                  There's also an extra OTP Secu.R...
                  09-06-2025, 05:47 PM
                • bondminer009
                  Need Bios for Latitude 7650 (No Original / dump bios file)
                  by bondminer009
                  Good Evening,
                  Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                  Thank You
                  Salam,
                  Three
                  11-12-2024, 07:48 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • joshAU
                  BIOS file for N550JK (original dump attached)
                  by joshAU
                  Hi all.
                  I'm looking for a BIOS file for an Asus N550JK.
                  I have a Asus R552J, which I believe is identical to the Asus N550JK.
                  I downloaded the latest BIOS (210) for the R552.
                  It is named N550JKAS.210.
                  The BIOS file is however only 6mb in size.
                  I've read the chip with a CH341A programmer and verified the file.
                  That file is actually 8mb in size.
                  I'm wanting to remove the BIOS password from this unit.
                  It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                  08-09-2022, 08:06 PM
                • adelage
                  Merge ECS Z77-H2 bios cap file with original dump
                  by adelage
                  I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                  03-11-2025, 03:07 AM
