HP ProOne 400 G4
  • kulokutoys
    • Jun 2010
    • 127
    • Phillippines
    HP ProOne 400 G4
    P/N: 4Vw69PT#A2k
    S/N: 8CG8426G7K
    Board : 348.0B723.0021 17564-2
    Repair/Clean
    no post with beep 3 long 4short
  • hoaca388
    Badcaps
    • Jan 2022
    • 11193
    • Viet Nam
    Re: HP ProOne 400 G4
    Originally posted by kulokutoys
    P/N: 4Vw69PT#A2k
    S/N: 8CG8426G7K
    Repair/Clean
    Post more main bios file from 2nd chip, the one you posted is just EC file.
    • kulokutoys
      • Jun 2010
      • 127
      • Phillippines
      thank you
      • hoaca388
        Badcaps
        • Jan 2022
        • 11193
        • Viet Nam
        thank you
        New main bios and EC file.
        • kulokutoys
          • Jun 2010
          • 127
          • Phillippines
          thank you so much. your the best! works like magic
          • rakibul85
            • Mar 2017
            • 26
            • Bangladesh
            tnx
            • dspok
              • Jan 2014
              • 553
              • Nepal
              HP ProOne 400 G4 20 No Display BAD 16MB chip, I replaced chip with frimware from support, system turns on but to display.
              SN: 8CG9251RJR
              Attached 32MB
              Please fix.
                • 20311
                SN: 8CG9251RJR
                Attached 32MB
                Please fix.
                The latest bios update from support contains "Q12_022700.bin" after extracting the exe ,the size is 28,258KB .The bios region that can be copied from that,with a hex editor, is 16MB, it is meant as an update to the main bios, its not for the 16MB BIOS_EC .
                • dspok
                  • Jan 2014
                  • 553
                  • Nepal
                  Where can I get EC? as above EC won't work.
                  Can I extract from main?
                    • 20311
                    post #4
                    • WyasW
                      • Feb 2019
                      • 11
                      • turkey
                      hi everyone, it worked but now i have another problem after boot i got kind of error ,,there is a problem with the hp endpoint security,,
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11193
                        • Viet Nam
                        Post your serial number and backup bios file.
                        • WyasW
                          • Feb 2019
                          • 11
                          • turkey
                          sir i don't have backup it's changed before SN: 8CG8295782
                          • WyasW
                            • Feb 2019
                            • 11
                            • turkey
                            sir SN is it enough?
                              • 20311
                              Try this, read the README.txt file for instructions - https://www.badcaps.net/forum/troubl...07#post3571807
                              • WyasW
                                • Feb 2019
                                • 11
                                • turkey
                                i tried no post now
