HP EliteDesk 800 G2 TWR No Display - Bios
hello,
i have here hp elitedesk 800 G2 SFF
SN : CZC6059657
turns on no display
any help please!
Attached Filesif you find these attachements useful please consider making a small donation to the site
HP EliteDesk 800 G2 Base Model Small Form Factor PCAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Thread merged. Please read https://www.badcaps.net/forum/troubl...before-posting , type the PC serial number, post your backups.Badcaps relies on your donations to pay for hosting , site advertising goes nowhere near to covering these costs. If you have found my reply or post helpful please consider making a donation , thank you.Comment
I made a backup of Hp Elitedesk 800 G2 TWR but there is only 00 00 00,
serial number - CZC6069BPGAttached Filesif you find these attachements useful please consider making a small donation to the site
Brother, I accidentally cleared the chip. I have another such board and took a dump from it and flashed the broken board. But it did not help. I have another backup from a working board. Will this work?Attached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by lanoveyHello there,
I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle... -
Hello guys,
I stupidly tried to read out my BIOS & EC flash (with a clamp). This didn't work, I only read FF's. But after this operation, the PC is not longer turning on, just beeps 5 times (and blinks red) then 2 times (blinks white). The manual says this is the error code for: "The embedded controller cannot find valid firmware.".
I think it locked itself because of my experiment. Is this fixable? I now removed both chips from the board and dumped them, I attach the files in this post hoping someone can help me fix my stupid error. Thanks so much in advance anyone...-
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... - Loading...
